Thread: Neighbors 4t65 users a lot of transmission fluid
Results 1 to 9 of 9
  1. #1 Neighbors 4t65 users a lot of transmission fluid
    Kemmerer, Wyoming
    My new neighbor helped me move yesterday and has a 2001 gtp. He was saying he had to add at least a quart at every engine oil change. He hasn't noticed any leaks. What's the likelihood that it is a leak and just hasn't noticed or the transmission just uses that much fluid?
  2. #2 Re: Neighbors 4t65 users a lot of transmission fluid
    Buffalo
    What does his coolant overflow tank look like ?
  3. #3 Re: Neighbors 4t65 users a lot of transmission fluid
    its in his rad for sure if not on the ground, trannys are a hydraulic pump, they dont burn fluid like engine oil, they leak it only.
  4. #4 Re: Neighbors 4t65 users a lot of transmission fluid
    Kemmerer, Wyoming
    I'll have him check for leaks and look at his over flow tank
  5. #5 Re: Neighbors 4t65 users a lot of transmission fluid
    open the cap and look at the coolant. over flow tank wont tell the story as well.
  6. #6 Re: Neighbors 4t65 users a lot of transmission fluid
    Buffalo
    True. But the crap the skims off the top ends up in there looking like a pink white milkshake
  7. #7 Re: Neighbors 4t65 users a lot of transmission fluid
    Kemmerer, Wyoming
    The guy is a big dummy. He adds coolant a lot too. I'll probably help him change his lim gasket and all those other gaskets. It probably needs all kinds of basic maintenance
  8. #8 Re: Neighbors 4t65 users a lot of transmission fluid
    Still.. something ain't right if theres no visible leaks and the overflow hasn't overflowed with that much adding.
  9. #9 Re: Neighbors 4t65 users a lot of transmission fluid
    Kemmerer, Wyoming
    I wouldn't be surprised if there is a leak and he just hasn't seen it
  1. 03+ 4t65 transmission
    By l67ss in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-27-2013, 12:14 AM
