Thread: Won't shift or start
Results 1 to 6 of 6
  1. #1 Won't shift or start
    Wichita
    Something messed up when I shifted through reverse and into park today. The shifter is stuck either in reverse or in park. My gauge cluster now says revers & the shifter says park. I can't turn the car back on unless I jam the shifter as far forward as possible. Even when the car does turn on it wont shift at all. I will roll when off & when turned on.
    I've read it could be low tranny fluid, bad transmission, loose shifter cable. Aside from checking fluids I'm really not sure what to do here . . .
  2. #2 Re: Won't shift or start
    Banned - Busted For Scamming
    Feb 2009
    Sounds like something messed up with the shifter cable or the prndl switch on the tranny.
  3. #3 Re: Won't shift or start
    Wichita
    "prndl"? Okay how do I check this?
  4. #4 Re: Won't shift or start
    Wichita
    Ok I pressed the shift lock release button to see if I could shift & start the car. Car now shifts 1st through Drive. No NRP, so no start either. IDK whats wrong.
  5. #5 Re: Won't shift or start
    Wichita
    I'm guessing that I need to replace the switch on top of the tranny.
  6. #6 Re: Won't shift or start
    Wichita
    ^bump
    I really hope its not the shift solenoid
  1. Shift Kit[*]
    By Trannyman95 in forum How To Write-Ups/Tech Tips
    Last Post: 06-03-2012, 01:40 PM
  2. WBS shift kit...
    By Bogers99GTP in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 10-14-2008, 03:01 PM
  3. shift kit
    By YoungGTP in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 09-29-2008, 02:08 PM
  4. Getting a shift kit
    By ryangtp89 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-19-2008, 10:20 PM
