Thread: Time for a transmission?
Results 1 to 8 of 8
  1. #1 Time for a transmission?
    SE Level Member its me's Avatar
    Feb 2010
    KC, Kansas
    So, I bought this car a couple weeks ago and have had no real problems until just a the other night...
    I was driving down the highway and 55 mph and when I started to go up a hill my rpm's racked way up (almost as if it was in neutral) until I let up on the gas a little bit and then it seemed like it would come back into line and work like its supposed to? It done this a couple more times so I put the car in 3rd gear and limped her home with no more fits? I have drove the car around town a couple times since this happened and everything seems fine (but I haven't been back out on the highway to really check 4th gear). Does anybody have any thoughts on what might have been happening and how to fix the problem?
    I checked the fluid last night and it is full and looks and smells pretty fresh. But, when I checked it, it was just a little over full? Could that be a contributing factor to the cause of my delima? It wasn't extremly over filled, just about a quarter of an inch of the full line on the dipstick??
    Any and all help or suggestions will be graetly appriciated and concidered! Thank you in advance for any info due to the fact that I really don't know anyhting about transmissions other then how to change the filters and check the fluids!
  2. #2 Re: Time for a transmission?
    GTX Level Member cerick08GP's Avatar
    Just FYI stating your model, model year and mileage help narrow down many questions. Moving on, sounds to me like you lost ( or are losing) your 4th gear clutch hub a very common problem in the 97-02 transmissions. The good news is it will still work for a few months, but with out 4th gear you’ll get crappy mpg. The bad news is you need the tranny rebuilt. Good luck.
    Ten years of continuous driving excitement and counting!
    2008GP
    ||HV3 insert||PowerSlot rotors w/Hawks||LED interior||MSD 8.5mm
    2002GP||sold
  3. #3 Re: Time for a transmission?
    Feb 2010
    KC, Kansas
    Sorry for the lac of info about my car...
    99 Gtp
    about 175xxx miles
    After I posted this yestersay, I done a LOT of researching and was regretfully starting to lean towards that very same conclusion about my fouth gear clutch hub?
  4. #4 Re: Time for a transmission?
  5. #5 Re: Time for a transmission?
    May 2008
    McHenry IL
    see my trans thread LMAO
  6. #6 Re: Time for a transmission?
    GT Level Member Joe m's Avatar
    mesa,az
    coul;d be the 4th cluitch shaft aswell? my 4th went out and im replacing the shaft befor i do anyhting else with the trans
  7. #7 Re: Time for a transmission?
    May 2008
    McHenry IL
    do what i did.... your already in there replace everything interally for about 500 bucks from dave at triple edge performance you will thank yourself later
  8. #8 Re: Time for a transmission?
    Feb 2010
    KC, Kansas
    My brother (purplehaze) and I ended up replaceing the transission. It took us two solid days counting the time it took for us to go ahead and give her a nice suspension upgrade swapping out the springs and we had her back on the road again :-) Thanks again for all your help Hermano!!
  1. time for a new HU
    By QwikGT in forum Audio, Security & Visual Electronics
    Last Post: 12-15-2009, 04:13 PM
  2. Cam time
    By TheOtherNick in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-21-2009, 12:42 PM
  3. What is it THIS TIME!?
    By BwolfGT in forum Track Sessions and Kills
    Last Post: 10-19-2009, 12:06 AM
  4. first time post long time car owner
    By penstar66 in forum Introductions/Noob Questions
    Last Post: 02-11-2009, 03:54 AM
  5. Two Time'n
    By ajay in forum Introductions/Noob Questions
    Last Post: 02-09-2008, 06:56 PM
