Thread: 4T65E Hard Shift-Solution
Results 1 to 20 of 149
Threaded View
  1. #11 Re: 4T65E Hard Shift-Solution
    philippines
    I just went to an automatic transmission specialist here in the Philippines.
    He recommended that we change the 1-2 and 3-4 shift Solenoid because he said that this is the most common part that gets problems. Labor here is relatively cheap (about USD60.00 equivalent). The 2 shift solenoid is about USD30 each.
    I also asked him if we needed to change the (TCC) Transmission Control Circuit Solenoid and the Transmission Fluid Temp sensor, and he advised not to.
    No mention of the Pressure Control Solenoid though, nor the Accumulator spacers.
    What do you guys think?
    Also, if we change the Shift solenoid, is it also easy to change the TCC once we remove the Shift Solenoid?
    Thanks all.
  1. 5th brake hose "hard line" solution ~$6
    By alacran in forum Brakes/Suspension/Chassis
    Last Post: 07-04-2015, 01:18 AM
  2. 4T65E-HD lockup issue - engages really hard
    By paulaxe in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 08-03-2009, 09:25 PM
  3. hard shift
    By whitegtp in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 10-30-2008, 09:03 PM
  4. 5th brake hose -hard line solution ~$6
    By alacran in forum How To Write-Ups/Tech Tips
    Last Post: 10-02-2008, 08:18 PM
  5. Why is my 1st to 2nd shift so hard?
    By Andrew_99GTP in forum PCM Tuning
    Last Post: 04-26-2008, 08:35 AM
