Thread: 4T65E Hard Shift-Solution
Results 1 to 20 of 149
  1. #1 Re: 4T65E Hard Shift-Solution
    SE Level Member Piggy's Avatar
    Cincinnati, Ohio
    what are the inlet sizes? and do u plug the trans in and outlet one the radiator from where the thans oil originally went in and out?
  2. #2 Re: 4T65E Hard Shift-Solution
    New York
    Quote Originally Posted by Piggy View Post
    On My 2001 GP, the trans lines are both located on the passenger side of the radiator with the bottom metal line being the inlet line and the top line coming out of the radiator being the return line to the tranny. Just cut both lines with a tube cutter where they work their way over to the radiator to inlet/outlet side about half way across the bottom of the radiator and then use the rubber hose provided, which in my case, the Long Double Stack cooler provided to by pass the 2 OEM metal lines into and out of the radiator to go to the cooler in the grill. I don't know the diameter of the metal cooler lines but used the plastic caps that came with the Long cooler to cover the inlet/outlet ports of the cooler in shipping to cover the cut metal tranny lines into and out of the cooler that were no longer being used. Hope that helps!
  1. 5th brake hose "hard line" solution ~$6
    By alacran in forum Brakes/Suspension/Chassis
    Last Post: 07-04-2015, 01:18 AM
  2. 4T65E-HD lockup issue - engages really hard
    By paulaxe in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 08-03-2009, 09:25 PM
  3. hard shift
    By whitegtp in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 10-30-2008, 09:03 PM
  4. 5th brake hose -hard line solution ~$6
    By alacran in forum How To Write-Ups/Tech Tips
    Last Post: 10-02-2008, 08:18 PM
  5. Why is my 1st to 2nd shift so hard?
    By Andrew_99GTP in forum PCM Tuning
    Last Post: 04-26-2008, 08:35 AM
