Thread: 4T65E Hard Shift-Solution
Results 1 to 20 of 149
  1. #1 Re: 4T65E Hard Shift-Solution
    Michigan
    What a timely thread!! My 2000 GT recently began hard-shifting after 185,000 miles and I am looking at buying another tranny. Now I will be investigating this solution.
  2. #2 Re: 4T65E Hard Shift-Solution
    Virginia
    bsorenson, keep in mind that this issue is a pretty specific one that has to do with the pcm entering a mode where it commands full line pressure after it has detected too much slipping - or, maybe, the pressure control solenoid messes up and provides full pressure when it isn't supposed to. It operates almost on a toggle switch type of logic where the hard shifting starts, and if you shut the car down and turn it back on it goes back to being perfectly normal.
    In your case with 185K on the trans you might just be seeing an actual need for a rebuild. As the clutches wear and slip more the line pressure will be increased to compensate and you'll get hard shifts.
    I wouldn't necessarily say that the shift kit wouldn't help, and its not that expensive to try. So you could always give it a shot.
  1. 5th brake hose "hard line" solution ~$6
    By alacran in forum Brakes/Suspension/Chassis
    Last Post: 07-04-2015, 01:18 AM
  2. 4T65E-HD lockup issue - engages really hard
    By paulaxe in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 08-03-2009, 09:25 PM
  3. hard shift
    By whitegtp in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 10-30-2008, 09:03 PM
  4. 5th brake hose -hard line solution ~$6
    By alacran in forum How To Write-Ups/Tech Tips
    Last Post: 10-02-2008, 08:18 PM
  5. Why is my 1st to 2nd shift so hard?
    By Andrew_99GTP in forum PCM Tuning
    Last Post: 04-26-2008, 08:35 AM
