jbamonte
Would it be possible to post some pictures of the cooler and where you mounted it. Did you have to get alot of special tubing to plumb this in, I think you also stated you used Dexron VI, doesn't the owners manual specify Dexron III? My car has over 110000 miles on it, bought it used with 80000 miles on it and don't know when the fluid had been changed, the trany started doing exactly what you descibed just now and I checked the fluid it looked kind of bad but didn't really smell burnt, I sucked out as much as I could and repalced the fluid with new dexron III and still have the same problem. Is the Dexron fluid VI thicker and will help this problem? I'm thinking of doing what you sugested to see if it would help, would this problem be partly caused by a bad filter or really dirty filter.
