Thread: 4T65E Hard Shift-Solution
Results 1 to 20 of 147
  1. #1 Re: 4T65E Hard Shift-Solution
    Abbotsford British Columbia Canada EH!
    Hard shift update Finally!
    Upon reading jmamonte"s post, i concluded that I was willing to give this a try. I ordered the kit from ZZ Performance, then became bogged down with other life's issues, I finally installed the kit and have no more Hard-shift. It does shudder shift 1-2 when hot, but this is usually when the hard shifting would start. I had previously installed a small stacked plate cooler and am contemplating buying a larger one with a fan. I wish I knew how to over ride the cooling fans to turn on earlier, I think they are programmed to turn on at 230'F. ( any Ideas?) Maybe I'll just do a full overrideso their always on. So those trannys run HOT!!! And the hard shift issue only occurs when hot! I know that I am only buying myself some time before a rebuild. I had recently done a service and am using transynd ATF fluid (Good stuff thanks Allison!) Thanks Jmamonte your posts just bought me some valuable time. I was actually contemplating getting my wife a Toyota Sienna ( yuck). I'will give future updates as the ol Montana van is a real work horse, 232000 kms (145000miles) so we'll see how long this goes.
  2. #2 Re: 4T65E Hard Shift-Solution
    New York
    Quote Originally Posted by frugal View Post
    I installed 2 double stack 18,000 GVW tranny coolers one on each side under the bumper that do not run the transmission line through the radiator, the coolers do all the cooling. I choose that route since the radiator cooler will never get the trans fluid temperature lower than the coolant temperature which runs between 185-210 on my car on the gauge. I have not had a hard shift problem since the installation of the ZZP shift kit with the coolers since the fans run very often in the hotter weather with the A/C on and pull air over the cooler in the warmer weather. Obviously, winter driving is not a problem with the trans fluid running cool enough. I mounted the coolers in the grille above the lower bumper intakes and below the dual snorkel intakes up higher so you cannot see the cooler from the front of the car. I chose this location to protect the coolers from road debris and to lessen the cooling effect slightly in the extreme winter since they would not be exposed to direct cold air while the car was moving in the winter. The fans pull the air through the coolers in the summer with the A/C on. No issues in 6,000 miles of driving so far and the tranny shifts perfectly normal but my trans with 100,000 miles was not abused and the fluid was changed with filter 4X over its life. In my case with my setup and based on the condition of the tranny in general, I expect this setup will allow the transmission to run ten of thousands more miles with no problem from the hard shift issue as long as no other issues develop. Total cost for 2 Long double stack 18,000 GVW coolers and the ZZP shift kit was about $150. The coolers will also greatly extend the life of the tranny. I use Dexron VI and change the fluid every 20,000 miles or 3 years. Less is better!Hope that helps!
  3. #3 Re: 4T65E Hard Shift-Solution
    Jul 2017
    NE
    Did you get the coolers from zzp and everything came with it?
  4. #4 Re: 4T65E Hard Shift-Solution
    SE Level Member harrydunn's Avatar
    Oct 2008
    Columbia, Missouri
    ...I finally installed the kit and have no more Hard-shift. It does shudder shift 1-2 when hot, but this is usually when the hard shifting would start...
    Bummer. I was onboard with this until you stated the 1-2 shudder is still there. I've got the typical 15-25 mph 1-2 shudder and the nice "whine" sound. If I go ahead and step on it a bit, shifts great.
    Oh heck, maybe I'll just try it. If it got rid of the whine, that would be a small victory I suppose.
    Your thoughts?
    2001 Fire Red Metallic GTP, 60K miles
    1993 Toyota Land Cruiser FZJ80
  5. #5 Re: 4T65E Hard Shift-Solution
    Its worth a try, the shift kit is just some plastic dowels, you could easily just make one, take apart the accumulators and place the dowels on the rods,( it just limits accumulator piston travel) I could scan and email instructions as to where the dowels go. i personally couldn't believe i paid money for some small plastic dowels , but it worked for me. i find that the tranny only shudder shifts when hot in stop and go driving, i have a tranny cooler albeit a small one, I want to get my fans to turn on sooner but discovered that this is controlled by the PCM. I could wire in something but that's a lot of hassle. Could get the PCM retuned to turn on fans at a lower temp. (overkill Motorsports) Maybe i'll install one of those tranny coolers with a fan from B&M. the real fix is a rebuilt trans from a specialist like triple edge performance,
  6. #6 Re: 4T65E Hard Shift-Solution
    Oct 2008
    Columbia, Missouri
    Mine only shudders around town when hot so it doesn't sound like I would benefit much. My former 2000 Bonneville and now 2001 Grand Prix have both been very disappointing with regards to their transmissions. I love the engines however. Roll with the punches I suppose.
  1. 5th brake hose "hard line" solution ~$6
    By alacran in forum Brakes/Suspension/Chassis
    Last Post: 07-04-2015, 01:18 AM
  2. 4T65E-HD lockup issue - engages really hard
    By paulaxe in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 08-03-2009, 09:25 PM
  3. hard shift
    By whitegtp in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 10-30-2008, 09:03 PM
  4. 5th brake hose -hard line solution ~$6
    By alacran in forum How To Write-Ups/Tech Tips
    Last Post: 10-02-2008, 08:18 PM
  5. Why is my 1st to 2nd shift so hard?
    By Andrew_99GTP in forum PCM Tuning
    Last Post: 04-26-2008, 08:35 AM
