Thread: external range sensor
Results 1 to 5 of 5
Threaded View
  1. #3 Re: external range sensor
    SE Level Member CRAZYC's Avatar
    Nov 2009
    Detroit
    Quote Originally Posted by Trannyman95 View Post
    For cooler lines you will have to use the quick connect lines that match the trans....
    what quick connect lines match the trans?
    - pics?
    i read the sticky... seems like more work than i bargain for?
    if i could just use quick connects thats fine for me.
    - pics?
    i read that they may leak sometimes or in the future, but im just using car as daily driver, so i will watch for leaks, no High Performance use for me...
    so if i have both cooler lines from both cars, will i have what i need???
    do i have to worry about check balls??? - im picking up trans tomorrow......
  1. External hard drive
    By joshua_arndt in forum Off Topic Discussion
    Last Post: 10-10-2009, 06:39 PM
  2. Bad MAP??? What should the range be?
    By l67fiero in forum PCM Tuning
    Last Post: 08-14-2009, 01:54 PM
  3. plug heat range....
    Last Post: 08-12-2009, 06:30 PM
  4. Engine Temperature Normal Range...
    By Chris in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-15-2009, 08:17 AM
  5. 05 GTP Comp G OEM Remote Start Range
    By Jester331gt in forum General Tech Discussion
    Last Post: 01-04-2009, 08:54 PM
