Thread: external range sensor
Results 1 to 5 of 5
Threaded View
CRAZYC external range sensor 11-05-2009, 12:39 AM
Trannyman95 Re: external range sensor 11-05-2009, 01:08 PM
CRAZYC Re: external range sensor 11-05-2009, 07:40 PM
Trannyman95 Re: external range sensor 11-10-2009, 01:01 AM
thomas Re: external range sensor 11-19-2009, 05:14 PM
  1. #1 external range sensor
    SE Level Member CRAZYC's Avatar
    Nov 2009
    Detroit
    Hello, i have a 98 GP GTP - my transmission went out completely. it doesnt go in drive, reverse, nothing...
    Anyways, i found a trans from a 2001 GP GTP, low milage, and was wondering about the trans lines and range sensor.
    i figure trans lines runs from trans different, diff. fittings? or different angle/path?? but hook up to radiator same way... but where is the range sensor located ??? does n e one have a picture, or general knowledge of its location ??? what is involved with hooking up an external range sensor as opposed to internal???
    Oh, also what is the big deal about cooling line fittings and check balls???
    do i use my 2001 trans lines/fittings/checkballs or do i keep my 98 trans stuff???
    i got these from other posts:
    Quote Originally Posted by Scimmia View Post
    The range sensors aren't an issue since they're both Grand Prixs. As Bill said, swap the lines and you should be fine.
    you may or may not need the external range sensor...if you do it's a quick easy install.
    Quote Originally Posted by Trannyman95 View Post
    Heres the low-down on cooler line fitting thread sizes.....
    You MUST USE A FITTING WITH A CHECKBALL IF THE TRANS CAME WITH ONE!!!! The ONLY exception to this is if the transmission is apart and being rebuilt you can install an internal checkball like what was used on the 97-99 and 04+ units. It is in the channel plate. It doesnt matter where it is located but there has to be one in one spot or another.
  1. External hard drive
    By joshua_arndt in forum Off Topic Discussion
    Last Post: 10-10-2009, 06:39 PM
  2. Bad MAP??? What should the range be?
    By l67fiero in forum PCM Tuning
    Last Post: 08-14-2009, 01:54 PM
  3. plug heat range....
    Last Post: 08-12-2009, 06:30 PM
  4. Engine Temperature Normal Range...
    By Chris in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-15-2009, 08:17 AM
  5. 05 GTP Comp G OEM Remote Start Range
    By Jester331gt in forum General Tech Discussion
    Last Post: 01-04-2009, 08:54 PM
