Thread: Possible Final Thread, Trans Issue
Results 1 to 8 of 8
  1. #1 Possible Final Thread, Trans Issue
    GT Level Member GPSims39's Avatar
    Nov 2008
    Hauppauge, NY
    Ok, most of you have seen my little saga in the General Tech forum, however this is now a trans issue, heres the low down:
    Replaced Battery Tuesday 3/17. Car drove fine prior and after. Start car on Wed, horrible clacking sound from engine that faded in and out, trans shifted odd. Same thing going home, trans started to slip. Thrusday on way to work, lost all gears stranded on side of the road. When car is cold it shifts into gear and goes R1234 no issue, however there is a clacking noise, when warm no clacking noise, no gears, R-1 on shifter. Pumped out fluid replaced with Dex 6 and lucas, same result fine when cold, nothing when warm. Ideas? Thoughts? Prayers? Donations???
  2. #2 Re: Possible Final Thread, Trans Issue
    Nov 2008
    Hauppauge, NY
    Ok, i have sent the car to the trans shop, same issue where it sounds like the pump is screaming to get fluid though the filter and then simply cuts out when warm to not damage the trans hence the no gears when warm. after speaking with Trannyman and a few people who have a lot of automotive experrience, they all seem to agree that it is indeed the filter and a simple change n flush will do the trick for now. Not saying that there isnt an issue with the trans, it is possible that there is an underlying problem that coudl still be wearing to have caused the trans to clogg up. it is also possible that since no service was ever done that like an oil and air filter, the years of ware has dirtied the filter. In my experience when something has gone on a trans, you hear it, a pop, a bang and marbles in a blender (happend to me twice prior in my oldcar), none of which is happening with my car and when cold shifts great. The trans shop immedietly with out looking at it said that there is an internal problem and wants 1500 to rebuild, i said no, there were no codes and dont have 1500 so im just waiting on them to do a tranny service and clean her out, im hoping this will give me some new life for a little bit longer.
  3. #3 Re: Possible Final Thread, Trans Issue
    CT
    $1500 for a triple edge transmission is more worth it......if it came down to that.
  4. #4 Re: Possible Final Thread, Trans Issue
    Nov 2008
    Hauppauge, NY
    got the car for 700, not only dont i have 1500 for a new trans, but its not worth it in an old car,
  5. #5 Re: Possible Final Thread, Trans Issue
    Nov 2008
    Hauppauge, NY
    VICTORY!!!!!!!
    Drives like new!!! as soon as i started her up, after the tranny shop said i might need a tow back and to take the card, i noticed the pump stopped screaming, she shifts like new, 2-3-4 Lock Up All picture perfect, looks like 12 years of wear and the filter had enough, they said there was some metal in the pan, but again 12 years of wear there will be metal in there, not bad for a 37 dollar fix new filter, fluid cleaned out niceeee
  6. #6 Re: Possible Final Thread, Trans Issue
    GTP Level Member dstout's Avatar
    ky
    12 years and the fluid and filter were never changed? WOW Holy Sh*t!! How many miles do you have on the car?
    I guess you should be pretty happy eh?
  7. #7 Re: Possible Final Thread, Trans Issue
    Nov 2008
    Hauppauge, NY
    104000 on the car, i just got it in november, and it was never done, i was gonna do it myself but it was too cold here to do, and the day i planned on doing it cause it got warm was the day it acted up, and didnt know what happend, but yeah very happy im gonna get it done every 12-15k to ensure a long lasting tranny
  8. #8 Re: Possible Final Thread, Trans Issue
    ky
    thats a good idea
  1. final opinions
    By uNda6gT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-30-2009, 08:37 AM
  2. What is the final call with DEXCOOL
    By Onthebrinc in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-11-2008, 12:13 AM
  3. Changing internal gearing? (not final drive)
    By Ron Vogel in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-13-2008, 02:27 AM
  4. My almost certain final moment on ClubGP
    Last Post: 01-30-2008, 12:18 PM
  5. Final step of tinting my tails need a lil help please
    Last Post: 12-27-2007, 08:44 AM
