Thread: Fluid Leaking out of Axle Seal Still
Results 1 to 15 of 15
  1. #1 Re: Fluid Leaking out of Axle Seal Still
    Transmission Expert Trannyman95's Avatar
    Fort Wayne, IN
    Make sure the spring doesnt pop out of the back side of the seal when you are tapping it in as no spring = leak.
  2. #2 Re: Fluid Leaking out of Axle Seal Still
    SE Level Member Metallistar's Avatar
    I dont remember seeing a spring...
  3. #3 Re: Fluid Leaking out of Axle Seal Still
    Fort Wayne, IN
    You wont see the spring, it is on the back side of the seal and is held by the lip molded in the back side of the seal. If you look at a new on you will see what I am talking about. It is called a worm spring and it keeps tension on the seal against the shaft. It is possible to pop the spring out while you are pounding in the new seal.
  1. Axle Seal Replacement [*]
    By Metallistar in forum How To Write-Ups/Tech Tips
    Last Post: 01-21-2012, 09:25 PM
  2. What Tranny Fluid should I run?
    By Iron Indian in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-15-2009, 01:24 PM
  3. Gasket/Leaking problem
    By Phil_GTP in forum 3.4L V6 (LQ1) DOHC
    Last Post: 10-13-2008, 01:48 PM
  4. fuel line leaking
    By bayareagtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-15-2008, 03:08 AM
