Thread: Fluid Leaking out of Axle Seal Still
Results 1 to 15 of 15
  1. #1 Fluid Leaking out of Axle Seal Still
    SE Level Member Metallistar's Avatar
    Ok, so I replaced the Axle Seal on the drivers side of the tranny and I thought all was ok, but now fluid is seeping out of the new seal. What else could be wrong?
  2. #2 Re: Fluid Leaking out of Axle Seal Still
    Oklahoma
    Well I hate to be the one to ask an obvious and probably silly question, but are you sure you used the correct seal? And are you sure the leak is coming from the seal?
  3. #3 Re: Fluid Leaking out of Axle Seal Still
    GTX Level Member MTXGTP's Avatar
    wamego,KS
    also you have to be ALL the dirt was clear of it.
    Justin Young, Kansas
    1999 silver GTP DHP pcm,3" Cattless hogan DP,Front PLOG,3.4 pulley, ported TB, ported LIM, ported supercharger housing.porting done by GBP
    coming soon: LS6 springs ,1.9rr
  4. #4 Re: Fluid Leaking out of Axle Seal Still
    GXP Level Member Zef_66's Avatar
    PA
    It could be that the fluid is leaking out between the seal and the axle shaft. The axle shaft may be undersized, worn down, or something. You might have to replace the axle...
    2001 GSE
  5. #5 Re: Fluid Leaking out of Axle Seal Still
    Oklahoma
    Quote Originally Posted by Zef_66 View Post
    Why dont I think of these things.
  6. #6 Re: Fluid Leaking out of Axle Seal Still
    Transmission Expert Trannyman95's Avatar
    Fort Wayne, IN
    I would also look very close at the area around where the seal goes. There is an oring in the side cover that seals up against the channel plate, which is where the seal goes, and if the oring is going bad or wasnt installed properly fluid can slowly seep from it. The only way to replace that is by removing the side cover. I would clean it all off good with parts cleaner and make sure it is dry and look carefully where the leak is coming from, maybe snap a pic and post it up where the wet area is.
  7. #7 Re: Fluid Leaking out of Axle Seal Still
    Quote Originally Posted by Trannyman95 View Post
    Ok, I'll do that tomorrow.
  8. #8 Re: Fluid Leaking out of Axle Seal Still
    Yeah, I'm going to do that next, I have a spare drive cup I can throw in there and see if it still leaks. I also have a spare axle seal, so if thats the problem I can rip that one out and replace it again.
  9. #9 Re: Fluid Leaking out of Axle Seal Still
    Fort Wayne, IN
    Make sure the spring doesnt pop out of the back side of the seal when you are tapping it in as no spring = leak.
  10. #10 Re: Fluid Leaking out of Axle Seal Still
    I dont remember seeing a spring...
  11. #11 Re: Fluid Leaking out of Axle Seal Still
    Fort Wayne, IN
    You wont see the spring, it is on the back side of the seal and is held by the lip molded in the back side of the seal. If you look at a new on you will see what I am talking about. It is called a worm spring and it keeps tension on the seal against the shaft. It is possible to pop the spring out while you are pounding in the new seal.
  12. #12 Re: Fluid Leaking out of Axle Seal Still
    Ok, just wanted to say, that Trannyman was right, the little spring in the seal was ever so slightly poped out so it wasnt sealing on the inner surface and causing it to leak. Put another seal in there and now every thing is leak free.
    Thanks for all your help Trannyman!
  13. #13 Re: Fluid Leaking out of Axle Seal Still
    Oklahoma
    Thats good, if I may recommend, take a moment to click on his reputation icon and click 'I approve' and leave a brief comment. Something short stating how he helped you out.
  1. Axle Seal Replacement [*]
    By Metallistar in forum How To Write-Ups/Tech Tips
    Last Post: 01-21-2012, 09:25 PM
  2. What Tranny Fluid should I run?
    By Iron Indian in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-15-2009, 01:24 PM
  3. Gasket/Leaking problem
    By Phil_GTP in forum 3.4L V6 (LQ1) DOHC
    Last Post: 10-13-2008, 01:48 PM
  4. fuel line leaking
    By bayareagtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-15-2008, 03:08 AM
