Thread: Fluid Leaking out of Axle Seal Still
Results 1 to 15 of 15
Threaded View
  1. #8 Re: Fluid Leaking out of Axle Seal Still
    SE Level Member Metallistar's Avatar
    Ok, I took a pic of the leak, let me know if you need a better angle or something, kind of hard with the tie rod and sway bar in the way.
    Edit: That was after I cleaned the area and let dry, then started the car and ran it through the gears for about 2 mins.
    Fluid Leaking out of Axle Seal Still Attached Images
  1. Axle Seal Replacement [*]
    By Metallistar in forum How To Write-Ups/Tech Tips
    Last Post: 01-21-2012, 09:25 PM
  2. What Tranny Fluid should I run?
    By Iron Indian in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-15-2009, 01:24 PM
  3. Gasket/Leaking problem
    By Phil_GTP in forum 3.4L V6 (LQ1) DOHC
    Last Post: 10-13-2008, 01:48 PM
  4. fuel line leaking
    By bayareagtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-15-2008, 03:08 AM
