Thread: Replace Pressure Control Solenoid
Results 1 to 6 of 6
  1. #1 Replace Pressure Control Solenoid
    Aug 2011
    Wareham, MA
    Have a transmission problem with my 2000 GT. Brought to Aamco to get diagnosis and pull any codes. They gave me P0748 and told me it could be one of a few electrical issues. P0748 refers to the Pressure Control Solenoid. I would like to know if anyone has replaced the PCS themselves and if so what work is involved and if you can replace it without taking the tranny off the car. Thanks.
  2. #2 Re: Replace Pressure Control Solenoid
    Quincy, Mass
    i havent done one but it is inside the transmission in the valve body. it can be done in the car, you have to drop the sub frame to get to it and take the side cover off the transmission. you could buy an already rebuilt valve body and it would make the job alot easier and it replaces the solenoids and stuff.
    No more GP 04 Impala SS Indy:
  3. #3 Re: Replace Pressure Control Solenoid
    Transmission Expert Trannyman95's Avatar
    Fort Wayne, IN
    Before you dive into replacing the solenoid you need to ohm check it to determine if it is even bad. The best place to start is right at the pcm connector and use an ohm meter to check the resistance between the two wires for the pcs that go to the trans. There are ohm specs for the solenoids on our website for reference. You will need to get a pcm connector pinout picture and schematic to find the correct wires but this is a must-do step. You should also check each wire to ground and also measure each wire from the pcm connector to the transmission connector to make sure there is not a broken wire or one rubbed through and shorted to ground. A common wear area is just under the air box near the AC accumulator and lines where the harness lays on it. After the external wiring has been verified good/bad and if ok then you should do an ohm check right at the trans connector itself to check the solenoid resistance and if found bad right at the trans then it could be a bad internal transmission wire harness or the solenoid and that would require dropping the transmission down to remove the side cover for repair.
  4. #4 Re: Replace Pressure Control Solenoid
    SE Level Member BLWNPontiacs's Avatar
    Sep 2011
    Bucks County PA
    Quote Originally Posted by Trannyman95 View Post
    Absolutely correct, great post.
    -09 BMW 328i Xdrive
    -06 LSM GXP-Factory Nav & moonroof, stock...for now.
    -98 Silvermist GTP Coupe-Getting junked or parted out.
    -09 G8 GT-Totaled due to some dumbass 18yr old kid
  5. #5 Re: Replace Pressure Control Solenoid
    SE Level Member Wakingcrow's Avatar
    Mar 2017
    Florida
    What does that connector look like and is it on the passenger side? Above the speed sensor somewhere?
  6. #6 Re: Replace Pressure Control Solenoid
    Mar 2014
    Tucson
    Drivers side. Near the top.
    Replace Pressure Control Solenoid Attached Images
  1. pressure control solenoid ?s
    By circa09 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 04-11-2011, 03:53 PM
  2. Pressure control solenoid?? HELP
    By gtpman in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 09-14-2010, 08:56 AM
  3. Pressure Control Solenoid?
    By Klutch in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 08-04-2009, 01:09 AM
  4. Pressure control solenoid, anyone got a writeup on changing it?
    By Merlin in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 04-29-2009, 11:05 PM
