Thread: Trouble codes after tranny install
Results 1 to 9 of 9
  1. #1 Trouble codes after tranny install
    Wichita
    Just got my tranny installed and car seems to run and drive fine bar 2 things. I'm getting DTC's P0700 and P2764. TCC pressure control solenoid low voltage. And my traction control says its needs service. I've checked and cleaned all my connections and couldnt find any frayed wires or bad connections. I'm at a bit of a loss. Or can this be caused by ground wires? I think when I put the tranny back in 4 ground wires ended up sharing the same spot. Idk I need some here, please.
  2. #2 Re: Trouble codes after tranny install
    this a used tranny? or a rebuilt unit by the shop?
  3. #3 Re: Trouble codes after tranny install
    Wichita
    Just had 2nd gear clutch replaced. I installed the tranny myself.
  4. #4 Re: Trouble codes after tranny install
    they may have broken the harness inside the cover. its a brittle pos. can break and not know it.
  5. #5 Re: Trouble codes after tranny install
    Wichita
    Oh dang! Well, Its going back to them on Monday. Guess I'll find out then.
  6. #6 Re: Trouble codes after tranny install
    Wichita
    Had to get a new Pressure Solenoid. 😑
  7. #7 Re: Trouble codes after tranny install
    GTX Level Member wstefan20's Avatar
    Aug 2017
    Raytown, MO
    Owch. This is why I refuse to just "fix the one issue" and bolt it back up. I always at bare minimum replace all clutches, inspect, and replace all solenoids. All solenoids are something like $80 so it's cheap insurance against having to rebuild it down the road. At that point, an entire master rebuilt kit is only $500 including the solenoids, so I almost never do a partial rebuild for this exact reason.
    Glad to hear they are taking care of it though. I know installing these transmissions are a pita so I feel your pain having to pull it again. At least you can save money there!
  8. #8 Re: Trouble codes after tranny install
    Wichita
    Mmm feels good to have the GXP back, and it runs great now. Sadly the traction control lights are still screaming at me. I'll figure it out. Eventually
  9. #9 Re: Trouble codes after tranny install
    Check your wheel bearings.
  1. Couple of Codes after Tranny install. Hmmm
    By Brian99SE in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 06-28-2012, 11:10 PM
  2. Trouble codes after header install
    By dsmuts in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-06-2011, 04:13 PM
  3. trouble codes
    By grand2000prixgtp in forum Off Topic Discussion
    Last Post: 10-16-2009, 07:35 AM
  4. trouble codes
    By grand2000prixgtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-19-2009, 02:32 PM
  5. trouble codes
    By BADAZGTP in forum Forum Bugs/Suggestions
    Last Post: 07-26-2008, 10:59 AM
