Thread: PRND321 Not lighting up in cluster
Page 2 of 2 FirstFirst 12
Results 21 to 28 of 28
  1. #1 Re: PRND321 Not lighting up in cluster
    Jun 2016
    Edmonton
    I just looked at the right up and noticed that his PRND321 is not working lol
    i sent a message to The Guz that did the write up maybe he has a fix
  2. #2 Re: PRND321 Not lighting up in cluster
    http://www.grandprixforums.net/threa...-Install/page3 post 60 and the one above it shows that dot lit, and not lit up.
  3. #3 Re: PRND321 Not lighting up in cluster
    Jul 2010
    Coquitlam,BC,Canada
    Why would there be 7 leds if a bulb illuminates that area?
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  4. #4 Re: PRND321 Not lighting up in cluster
    Jun 2016
    Edmonton
    It's just one of those things that should be working. In a couple years this car will be my sons
  5. #5 Re: PRND321 Not lighting up in cluster
    Dec 2008
    Lawndale, CA
    That slotted indicators under the PRND321 is lit up by those LED's on that circuit board. The indicators under the letters only come on when the car is on and running. The actual lettering appears brighter after I swapped in the LEDs is due to bleed through from the larger bulb that sits over that area.
    So either all the LED's burnt out, there is a burnt out component on the board, there is a cold solder joint somewhere or the connector was loose and needs to be reseated. Based on the photo is appears the no components are burned out.
    If you are looking for the easiest solution with less headache, a junkyard piece would be the way to go. If you wish to tackle this project on your ouwn, you could try swapping out those 7 LED's for new ones.
  6. #6 Re: PRND321 Not lighting up in cluster
    Jun 2016
    Edmonton
    Went over the board with volt meter and the board is not getting any electricity
    so there is a wire that must be broken somewhere
  7. #7 Re: PRND321 Not lighting up in cluster
    Quote Originally Posted by Bronco Boy View Post
    Damn it all. Looks like Scotty is right..... again! LOL
    Thanks for the pics of the board GTPishere. Good to know what is under there.
    he's got to mean the dot under the prnd321. it seems to be lit up at random times and not in others. why idk. would i give a crap, hell no. unless it a bulb, that would bug be to death lol the dot, id not care if i ever seen it again. i shift it by feel. never look.
  8. #8 Re: PRND321 Not lighting up in cluster
    Jul 2010
    Coquitlam,BC,Canada
    The dot. Yes! I was starting to wonder the same thing. Mine has always worked so I don't give a crap either. LOL
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  1. instrument cluster lighting
    By primem in forum General Grand Prix Discussion
    Last Post: 10-10-2013, 09:30 PM
  2. Only Half of Gauge Cluster Lighting Up But Bulbs Are Good??? 03 GTP
    By WaterBoy in forum General Tech Discussion
    Last Post: 02-07-2012, 09:55 AM
