I just looked at the right up and noticed that his PRND321 is not working lol
i sent a message to The Guz that did the write up maybe he has a fix
http://www.grandprixforums.net/threa...-Install/page3 post 60 and the one above it shows that dot lit, and not lit up.
Why would there be 7 leds if a bulb illuminates that area?
he's got to mean the dot under the prnd321. it seems to be lit up at random times and not in others. why idk. would i give a crap, hell no. unless it a bulb, that would bug be to death lol the dot, id not care if i ever seen it again. i shift it by feel. never look.
It's just one of those things that should be working. In a couple years this car will be my sons
That slotted indicators under the PRND321 is lit up by those LED's on that circuit board. The indicators under the letters only come on when the car is on and running. The actual lettering appears brighter after I swapped in the LEDs is due to bleed through from the larger bulb that sits over that area.
So either all the LED's burnt out, there is a burnt out component on the board, there is a cold solder joint somewhere or the connector was loose and needs to be reseated. Based on the photo is appears the no components are burned out.
If you are looking for the easiest solution with less headache, a junkyard piece would be the way to go. If you wish to tackle this project on your ouwn, you could try swapping out those 7 LED's for new ones.
Went over the board with volt meter and the board is not getting any electricity
so there is a wire that must be broken somewhere
