Thread: Screeching Tranny
Results 1 to 6 of 6
  1. #1 Screeching Tranny
    SE Level Member thekidinbuff's Avatar
    May 2013
    Buffalo, NY
    If you start the car in park or neutral, about 3 seconds after the car has started, theres a very very high pitch screech... If you move it to reverse, it stops. Also goes for Drive. But if you put it in Neutral, it will do it again.
    We started the car in park with the screeching and pushed and rocked the car against the parking pin and it stopped.
    So any idea? Can't really drive it.
    Thank you.
    2002 Pontiac Grand Prix GTP
    2006 Pontiac GTO LS2 M6
  2. #2 Re: Screeching Tranny
    Antioch, IL
    Starter trying to engage flywheel is my guess, my car does this in 3rd, but not 2nd or D. How to fix I dont know
    2009 Challenger SRT8
    Expert at being gay.
  3. #3 Re: Screeching Tranny
    May 2013
    Buffalo, NY
    I was thinking about that too. The flexplate looks fine though
  4. #4 Re: Screeching Tranny
    May 2013
    Buffalo, NY
    Turned out to be the remote start malfunctioning.... Shouldve tried it BEFORE i bought a new starter. I thought it was the Bendrix messing up but apparently not. At least my car cranks quieter now.
  5. #5 Re: Screeching Tranny
    St. Louis
    Maybe the starter gear isn't being pulled back in or the return spring is getting lazy and allowing the gear to contact the flexplate? Here's a thread that may help. You have to remove the inspection cover from the bottom of the trans to check it.
    http://www.grandprixforums.net/threa...-turning-right
  6. #6 Re: Screeching Tranny
    May 2013
    Buffalo, NY
    Thats what i believed what was wrong but it ended up being the aftermarket remote start, for some reason, energizing the starter when it got clearance that the car was running.
  1. Window Screeching
    By gordster1122 in forum General Tech Discussion
    Last Post: 03-09-2015, 06:52 PM
  2. Screeching while turning right! Help!!
    By kyliek23 in forum General Grand Prix Discussion
    Last Post: 10-17-2014, 09:52 PM
  3. Screeching from wheel
    By Sulvestr in forum General Tech Discussion
    Last Post: 05-30-2014, 12:03 AM
  4. Belt Screeching
    By ILoveAudi in forum General Grand Prix Discussion
    Last Post: 09-24-2013, 01:37 PM
  5. Brakes screeching
    By Steven Monteith in forum Brakes/Suspension/Chassis
    Last Post: 10-19-2012, 12:56 AM
