Thread: Transmission Shifting Hard After Swap
Results 1 to 20 of 24
  1. #1 Transmission Shifting Hard After Swap
    SE Level Member walkure's Avatar
    Aug 2011
    Puyallup, WA
    My GT trans gave up and I swapped in a spare trans from a GTP. After this swap I copied over the stock trans tables from the GTP and also calibrated the speedometer. On the test drive the trans slams into each gear and shakes the whole car. Is there something that I missed or is the spare trans also done for?
  2. #2 Re: Transmission Shifting Hard After Swap
    I break things. WarStryker13's Avatar
    Oct 2014
    Frederick, MD
    did you swap the TC as well? I know the two have different stall speeds...
    04 GP GT2: Handling upgrades, go-slow parts, and an attitude. Totaled.
    87 Dodge Ram 50:​ Junkyard rescue, resurrection in progress.
  3. #3 Re: Transmission Shifting Hard After Swap
    what did you do to calibrated the speedometer? ive not seen that in dhp.
  4. #4 Re: Transmission Shifting Hard After Swap
    Aug 2011
    Puyallup, WA
    WarStryker13:
    I did change the TC to the larger GTP one because I think that is what failed.
    Scottydoggs:
    I am using HP tuners. It is Changing the drive sprocket ratio.
  5. #5 Re: Transmission Shifting Hard After Swap
    Mar 2014
    Tucson
    Here's the settings from my GTP:
  6. #6 Re: Transmission Shifting Hard After Swap
    Aug 2011
    Puyallup, WA
    That is exactly what I have. I'm starting to think that this spare also has issues.
  7. #7 Re: Transmission Shifting Hard After Swap
    Mar 2014
    Tucson
    I'm curious what your line pressure is. Sounds like you may be maxing out.
  8. #8 Re: Transmission Shifting Hard After Swap
    Aug 2011
    Puyallup, WA
    How do I test the line pressure?
  9. #9 Re: Transmission Shifting Hard After Swap
    Mar 2014
    Tucson
    https://www.youtube.com/watch?v=CNjDiPFcKuU
    I don't have a picture handy showing the pressure port, but it's not hard to find. Silver hex head plug accessible from the top.
  10. #10 Re: Transmission Shifting Hard After Swap
    you sure this is a gtp tranny? you had to swap an axle right? cause only one from the na tranny is the same.
  11. #11 Re: Transmission Shifting Hard After Swap
    Aug 2011
    Puyallup, WA
    Pretty damn sure. I have the donor car sitting behind the shop.
    I'll have to dig out a gauge and check the line pressure tonight.
  12. #12 Re: Transmission Shifting Hard After Swap
    ok, i had no idea how you came to own it. cause the wrong tranny or with the wrong tuning will also make it shift hard and then they eat them selves from it.
  13. #13 Re: Transmission Shifting Hard After Swap
    hangover park IL
    It can take up to 300 miles for trans adaptives to fully learn
  14. #14 Re: Transmission Shifting Hard After Swap
    Quote Originally Posted by Turbocharged400sbc View Post
    come to think of it, when we did my tranny swap it shifted pretty firm/harsh for a while, then mellowed out by the time i got home. aka 200 miles.
  15. #15 Re: Transmission Shifting Hard After Swap
    GXP Level Member Grimsin's Avatar
    St Thomas Ontario
    The diffs are the same right? I swapped to 3.69 gears and over kill forgot to change the diff setting as I also swapped the diff, it hard shifted till it was corrected
    3.8l N/A POWA! :4'' HAI\L67 HVTB\HV3\ER Rockers\WP underdrive pulley\Headers\cat delete\91 octane overkill incar tune.3.69 gears, Trans go shift kit.
    My Car:http://www.grandprixforums.net/threa...2005-Impala-LS
  16. #16 Re: Transmission Shifting Hard After Swap
    Aug 2011
    Puyallup, WA
    I'm hoping that it is just a shift adaptation issue. But I am going to check the PCS. When I drained the fluid it looked old and neglected which leads me to consider a solenoid issue. I'm just trying to put a bandaid on the car till I can save up for a TEP trans.
  17. #17 Re: Transmission Shifting Hard After Swap
    The issue is you did it in HPT. HPT doesn't show you all the tables and you are missing things. You really need DHP to copy the entire trans over and then it would be happy.
    Right now..it's pissy because of tables you can't see.
  18. #18 Re: Transmission Shifting Hard After Swap
    Aug 2011
    Puyallup, WA
    Well I'm stumped. Found out today that if you want to check trans pressure and have headers installed you are SOL. I'm going to see my local 3800 yoda tomorrow night and see what he can do.
  19. #19 Re: Transmission Shifting Hard After Swap
    this thread came from using dhp bin to hp, i did some other stuff hp cant do, emailed him the bin file and running off it now. http://www.grandprixforums.net/threa...er-of-Bin-File
    if it comes to it, i can make a na bin with the gtp tranny in dhp with the same osid # as your bin, then you need to follow that link i posted and change the vin # in the bin file so HPT will like it.
    if you have the old version of hp it will open and read, then flash the dhp bin file. as long as the osid and the vin match.
  20. #20 Re: Transmission Shifting Hard After Swap
    Aug 2011
    Puyallup, WA
    Well Bill was right. I took the car to a friend and he made one change using DHP and the car now runs perfect.
  1. Shifting hard/jerking when shifting
    By Jonarin in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-16-2016, 11:00 AM
  2. 97 gtp trand shifting hard from 2nd to 3rd gear.update!!!! shifts hard in every gear?
    By Doug 97 gtp in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 11-12-2012, 12:18 PM
  3. Transmission shifting hard
    By bjm306 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 08-31-2012, 05:41 AM
  4. HELP!!! Transmission acting horrible, bucking, stuttering, grinding, shifting hard.
    By Lsick7 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 11-28-2009, 10:09 PM
  5. URGENT! Hard Shifting and Transmission Whine!!!
    By lvin4jc in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 10-21-2008, 08:46 PM
