So you might have read the other threads I have up, but this is something that has come up in the past 3 or so months.
Backstory: bought it 2.5 years ago in Germany, it ran...ok, dealership f-ed it up, blah blah blah... Replaced fluid and filter myself 2 years ago, dex IV and WIX, lots of clutch material, no shavings, problem appeared. No forward when cold, revving at a stop sign and slamming into gear, erratic shifts between 2-3, so I think time for a rebuild/replace. No money. Changed fluid/filter again 1 year ago, used 5 qts dex VI, 2 qts Slick50 trans treatment(couldn't get lucas), ACDelco filter, problem got slightly better. Shipped it over the sea to AK, seems to shift ok, slightly better than before. Stop driving due to issue with title, sat for 6 months over the winter. Hit -40* F a few times, kept it plugged in with oil pan heater, trans pan heater, battery heater, block heater, trickle charger. It started every time, no issues. Finally get the title for it from Germany, start driving it more often, still have the same issues but to a lesser extent. I have put about 350 miles on it since then.
FF to today... I realize that I no longer have any of the issues I had before, over 1 year ago. Trans shifts smooth all the way to 4th, I even tried WOT a few times, never seemed to phase the trans at all. I even got the tires to squeal a few times. I have done absolutely nothing to the transmission other than what I have listed above... Does anyone have an explanation for what could possibly be going on? Is it the additives? The new fluid doing some form of flush? Or do I have a unicorn behind my engine? I would like to know if anyone has ever seen this happen before...
