Hi everyone,
I am new to this forum. Have been on CGP for a few years. This question is already posted on CGP, but I figured that it would not hurt to post this to another forum to get additional feedback.
"I took a few days to put this one together and everything works except 1st gear. The car will not start out in 1st even if I manually put it in low gear.
I did all the major hard part upgrades: input shaft, pump shaft, output shaft, and 7/8th chain with stock gearing. I have a jzfm converter.
Other upgrades:
Superior AFL valve kit
Sonnax Boost Valve
Transgo Shift kit
Pawl Sprags
All solenoids replaced with new.
I also had to replace the differential with a stock unit.
It has about 50 easy miles on it. It is not overheating, running about 95C on a 95F night.
I was pretty confident that I assembled this one correctly. Have assembled other types of transmissions before with success, but this is my first 4t65e. Is it possible that I have a stuck solenoid or installed the input pawl sprag backwards? Any thoughts or ideas are appreciated. I don't want to pull the trans if I don't have an idea of what the problem could be."
