Thread: 6t70 six speed auto
Results 1 to 3 of 3
  1. #1 6t70 six speed auto
    GTX Level Member Travisgt2's Avatar
    Jan 2013
    leavenworth ks
    OK title says a lot I've done research now I want to know if anyone's tried it and will computers match up.
    04 GT2: 180 t-stat, cold air intake, reptile tune, plog, hv3, gt1 cam, 90#springs, new push rods, new lifters, port polished heads, lim, uim and tb, 06 Impala brakes and steel brake lines. Cosmetic: black roof rails, under glow, Pontiac ground light, blue hud dic radio controls and cluster. To come custom hood.
  2. #2 Re: 6t70 six speed auto
    GTP Level Member
    Apr 2012
    Las Vegas, Nv
    No.
    GPONA #1 Cyber Bully
  3. #3 Re: 6t70 six speed auto
    hangover park IL
    nope, you could do it via megasquirt 3 or MS3pro with the add on CAN bus GPIO.
    all the new tranny's are straight pwm shift solenoids, no more shuttle valves/etc.
    each gear has its own circuit/solenoid, you couldnt do it with the oem pcm as the pcm only controls two solenoids in 4 logic states
    ~James~ Psychotic Gearhead
  1. Will the GM 6T75 6 speed auto fit?
    By 00Daytona in forum General Tech Discussion
    Last Post: 10-22-2015, 10:11 AM
  2. 6T70 6-speed auto; has anyone swapped one into 3800?
    By April Thompson in forum General Tech Discussion
    Last Post: 02-04-2015, 09:17 AM
  3. 5 speed auto...
    By JunkBird69 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-05-2013, 11:53 AM
  4. 92 GP SE 3.1 v6 with 4 speed auto...ECM question
    By Geologist in forum General Grand Prix Discussion
    Last Post: 01-28-2013, 10:52 PM
  5. auto to 5 speed.
    By 2002Grandprix GT in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-31-2009, 09:40 PM
