Thread: Trans Issues after adding TEP VB, Input Shaft, and Chain....
Results 1 to 20 of 20
  1. #1 Trans Issues after adding TEP VB, Input Shaft, and Chain....
    Donating Users timboku's Avatar
    Montgomery, IL
    Alright been working on this project on and off for a little bit. I will try to make it short to see if anyone had input and can help. I sold my GXP so need my gtp up and running so I dont go through GP withdrawal
    I installed a TEP stage 2 VB, Dynotech Input Shaft, and 7/8ths 2.93 chain in to a 97 65eHD that is in my 2002 GTP. The trans has about 20k on a rebuild, Torque converter has less than 5k on it, Transgo Shift kit, and a Explorer trans cooler installed. The trans worked and shifted perfectly before I installed all this and the fluid was pink when drained before rebuild. All parts are Brand New.
    Problem:
    When put in D you need to rev it to 2500 RPM to get it to move, if you put in in 1, you get more power but still seems to slip. When you get up to about 20mph, it shifts and functions normally, Reverse works good. When put in drive, you never really feel it go into drive...the motor doesn't move like it does when put in Reverse. Also, the temps climb to 210 degrees after driving it for like 10 mins.
    I have had it apart numerous times to try to fix this.
    What I have done so far: With recommendations from Dave from TEP who has been great.
    -Re-torqued VB and channel plate,
    -Checked that check balls are in correct place (the first time one was missing my bad)
    -Pulled accumulator to make sure shift kit was installed correctly
    -Checked Forward band, it is intact and looks normal
    -Checked wire harness
    -Installed new AFL valve into channel plate
    - Re-torqued again VB again 3 times
    - Cleared pcm and left battery disconnected to clear TAPS
    -Hooked up Aeroforce and trans was starting in 2nd gear and never shifted originally after 2nd time dropping cradle. (i think a messed check ball in the channel plate caused this but it functions normally now and starts in 1st as it is supposed to)
    It seems to get better a little as it drives and learns, but something is not right as it feels like the trans does not catch.
    Questions I have:
    - In researching the 97 to 00 VB is different from a 01 to 02. as well as the check balls in the channel plate is different for the cooling check ball. It looks like i was sent a 02 VB as that is what Dave from TEP said it was. Is there any issues installing a 02 VB in a 97 trans with a 97 Channel plate? Dave said it does not matter?
    - Am I missing something, I followed the instructions in the Trans Manual to the T,
    - Gonna drop cradle again and pull side cover off. Was thinking of installing my old VB in to see if that changes anything??
    Any input would be awesome.
    Thanks in advance.
    2002 GTP..DD.. Topswapped Gen V L26, XP cam, Full Size IC, E85, 2.6 Pulley,SD Headers, K&N Intake, N*/Lq4,FP Rewire, TEP Trans, F body Fronts, GXP Rear Brakes, LE Spoiler, AGXs with vogtland springs, bonni gxp rims, Timboku Tuned
    1995 Cutlass Supreme Convertible...Soon to be L32Swapped.....2005 GXP Stock
  2. #2 Re: Trans Issues after adding TEP VB, Input Shaft, and Chain....
    Mar 2014
    Tucson
    I think the next step might be putting a pressure gauge on it.
  3. #3 Re: Trans Issues after adding TEP VB, Input Shaft, and Chain....
    Montgomery, IL
    Where do you hook up a pressure gauge to the trans?
  4. #4 Re: Trans Issues after adding TEP VB, Input Shaft, and Chain....
    Mar 2014
    Tucson
    Quote Originally Posted by timboku View Post
    There's a port on the top near the vent. Standard pipe thread, I think.
  5. #5 Re: Trans Issues after adding TEP VB, Input Shaft, and Chain....
    Montgomery, IL
    What kind of pressure gauge and what reading would I be looking for/at?
  6. #6 Re: Trans Issues after adding TEP VB, Input Shaft, and Chain....
    Mar 2014
    Tucson
    Should answer both questions:
  7. #7 Re: Trans Issues after adding TEP VB, Input Shaft, and Chain....
    without more info like Brandon already suggested that sounds a lot like a converter.... brandons got you down the right path though need to know more before you tear it apart again. also if them channel plates gaskets don't or are not sealing properly the fluid will bleed by and cause all sorts of goofy symptoms.... been there done that! twice actually.....
  8. #8 Re: Trans Issues after adding TEP VB, Input Shaft, and Chain....
    Mar 2014
    Tucson
    I mean... It's just a shot in the dark, but I'm leaning toward input piston.
    1.)
    2.)
    3.)
    Start with a pressure check though.
  9. #9 Re: Trans Issues after adding TEP VB, Input Shaft, and Chain....
    Montgomery, IL
    Thanks for the input..will get a pressure gauge and look at that first....hope it's not converter same converter it had before with like 5k on it brand new...
  10. #10 Re: Trans Issues after adding TEP VB, Input Shaft, and Chain....
    Mar 2014
    Tucson
    For me it's a toss up... Would you rather replace an input piston/seal or a torque converter?
  11. #11 Re: Trans Issues after adding TEP VB, Input Shaft, and Chain....
    Montgomery, IL
    So no one around has a pressure gauge to rent that I have found, but I unplugged the Trans connector to make it go to max pressure, and it work pretty good in drive...I know it's in limp mode, but it moved in drive better than it has...gonna keep looking or order a pressure gauge and see what the readings are...I still feel that it's something in the valve body or its not compatible with my channel cover....all bolts were torqued and retorqued on the vb and channel cover.
  12. #12 Re: Trans Issues after adding TEP VB, Input Shaft, and Chain....
    Mar 2014
    Tucson
    Any local trans shops offer a free diagnosis?
  13. #13 Re: Trans Issues after adding TEP VB, Input Shaft, and Chain....
    Bastard Reptile's Avatar
    Kansas City, MO
    A question that I will ask, since I ran into an issue with swapping different valve bodies in different years. And Dave can confirm if this is an issue.
    Did you use the correct year linkage for the valve body that you are putting in? By linkage, I'm talking about the plunger that actually connects the valve body to the transmission control linkage.
    I swapped valve bodies out of a newer year to an older year, and I had almost the exact same problem.
    Might not be related, but it's worth asking.
  14. #14 Re: Trans Issues after adding TEP VB, Input Shaft, and Chain....
    Montgomery, IL
    I did not swap anything from the old vb to the new one....I still have the old one and I will email Dave to see his thoughts...but in researching there are changes or differences in 97 to 00 and 01 to 02...I also have checkballs in the channel plate being a 97 for the cooler lines....I'll see what Dave says and go from there..at this point I feel like just throwing my old vb on to see how it runs...
  15. #15 Re: Trans Issues after adding TEP VB, Input Shaft, and Chain....
    Kansas City, MO
    The plunger is a different length between the years, that's why it's important to keep them matched.
    The check ball thing is easy, take the fitting off and knock the ball out. That may have something to do with it to, I had to do that now that I think of it.
  16. #16 Re: Trans Issues after adding TEP VB, Input Shaft, and Chain....
    Mar 2014
    Tucson
    Did you install the VB, IS and chain with the trans still in the car? Like, through the wheel well?
  17. #17 Re: Trans Issues after adding TEP VB, Input Shaft, and Chain....
    Montgomery, IL
    No I had it outta the cat when I put it all in....been dropping cradle and pulling side cover off to do stuff now.
  18. #18 Re: Trans Issues after adding TEP VB, Input Shaft, and Chain....
    Mar 2014
    Tucson
    Oh, okay. I was just wondering about the TCC o-ring on the IS. Sounds like you got it though.
  19. #19 Re: Trans Issues after adding TEP VB, Input Shaft, and Chain....
    Montgomery, IL
    I emailed Dave so hoping he has some more insight on the manual valve length and checkballs.
  20. #20 Re: Trans Issues after adding TEP VB, Input Shaft, and Chain....
    Montgomery, IL
    Yeah new o ring installed on the IS.....Its something in the VB I think and looks like the manual valve has something to do with it. Gonna drop it again next week on day off. Get it down to about 30 mins now..lol. Trans pan drain plug best mod ever right now...lol
  1. 4t65-hd built trans 300m input shaft 7/8 chain 2.93 gears
    By TwinV6GTP in forum Wanted To Buy - Parts
    Last Post: 01-21-2015, 02:28 PM
  2. DIY Input shaft and chain?
    By Frosty in forum General Tech Discussion
    Last Post: 12-17-2013, 05:26 PM
