Thread: Intense Shift kit
Results 1 to 20 of 24
  1. #1 Intense Shift kit
    GT Level Member Dadkota's Avatar
    Feb 2014
    Rhode Island
    I have just acquired an Intense Street/Strip Shift Kit for my GTP. Got it for free ($10 shipping) so I said yes to taking it no matter what, its brand new and never installed! What do people think of these shift kits? I see a lot of TransGo kits but not much on the Intense kit. Also, does my PCM need to be retuned if I get the shift kit installed?
    '01 GP GTP- Intake, Plog, 3" DP and Exhaust, DHP tuned by me, GMPP sway bars, 3.5 MPS, cold plugs and tstat
    -180,000 miles and climbing
  2. #2 Re: Intense Shift kit
    Mar 2014
    Tucson
    I don't have any direct experience with the Intense kit, but using their website as a reference, it looks like a pretty good kit. Good score for $10. Seems to have everything you need for the install also.
    Do the instructions give you a good idea of what springs and spacers give for shift feel? Like, use this spring and shim combo for a softer shift, or this spring and shim combo for a firmer shift...? The Trans-Go kit is kind of a "one size fits all." I think it's more for eliminating the P1811 code than for any kind of performance gains.
    You don't need to do anything to the tune, but it might be a good idea to disconnect the battery to reset the T.A.P. values.
  3. #3 Re: Intense Shift kit
    SE Level Member keatonregal's Avatar
    Mar 2015
    Port Huron, MI
    Not sure if it was the intense kit, It might have been the thrasher kit where people said it turned your trans into a monster lol, that kit was like $100 though, I think it was thrasher honestly, $10 for a shift kit is a great deal though
    1999 Buick Regal "Betty White"
    NIC Cam FSIC E85 Built Trans Flaky Paint
    Ported Aluminum Coolant Elbows
  4. #4 Re: Intense Shift kit
    Buffalo
    I personally installed this a couple of times now. Everything you need minus the fluid is there. Shifts on stock trans settings are quick not hard.
    i recommend this kit for its simplistic all you need in a bag but people don't like the spend the money
  5. #5 Re: Intense Shift kit
    Feb 2014
    Rhode Island
    I think it is more like "one size fits all", says under light/medium throttle I will get crisp shifts and under WOT, I'll get very firm shifts. It's definitely a great deal no matter how you look at it haha. Is it a hard install?
  6. #6 Re: Intense Shift kit
    Mar 2015
    Port Huron, MI
    Look up the install, its a sticky here somewhere...
  7. #7 Re: Intense Shift kit
    Buffalo
    It should come with a step by step with pictures instructions
  8. #8 Re: Intense Shift kit
    Feb 2014
    Rhode Island
    I have the pdf for the install, I'm just not very... "transmission savy" and I also don't have a lift or anything
  9. #9 Re: Intense Shift kit
    May 2012
    Where winter never ends
    1) remove pan and fluid
    2) remove filter
    3) remove accumulator
    4)open accumulator
    5) replace springs
    6) put back together in reverse with new gaskets.
    Theres a guide somewhere round here.
    2000 Regal - Winter Beater
  10. #10 Re: Intense Shift kit
    Feb 2014
    Rhode Island
    Is this a good kit for helping the trans last a bit longer? I have minor mods relatively, and its my daily driver. So I don't wanna destroy my trans haha
  11. #11 Re: Intense Shift kit
    Buffalo
    Is over hyped that it "destroys" or "isn't good" for a daily.
    For me my trans is already fairly fresh and it's good idea either way. I barely notice it unless you hammer down. It's very snappy and I'm sure my line pressure tables are not stock either
  12. #12 Re: Intense Shift kit
    Feb 2014
    Rhode Island
    I have read that it will help extend the life of the clutch packs and also lower the KR between shift too because it will shift quicker and firmer. I would like to install it, but only if its gonna help me
  13. #13 Re: Intense Shift kit
    Buffalo
    It will only help you. How can it not? You just listed a few reasons lol
  14. #14 Re: Intense Shift kit
    Mar 2014
    Tucson
    It sounds like you might be apprehensive about the installation. Don't be. It's not simple, but it is easy. Read the write up. Read it again. Do it when you have plenty of time and the trans is cold. Come back with any questions. I can give you the accumulator and pan bolt torque specs off memory.
  15. #15 Re: Intense Shift kit
    Feb 2014
    Rhode Island
    A manufacturer will say anything to sell a product, I just wanted to hear that stuff from Wbody guys who have experience in the field. And yea I am a bit on the fence about install. I am very comfortable with an engine but a transmission, especially a transaxle, is a whole other beast I have not yet conquered haha
  16. #16 Re: Intense Shift kit
    Feb 2014
    Rhode Island
    Also I just read that external trans cooler writeup you did, that's gonna be done around the same time as the shift kit probably! Great writeup and it does look incredibly professional haha
  17. #17 Re: Intense Shift kit
    Mar 2014
    Tucson
    Hey thanks! My only regret with that was running the return line back via the hard line and push lock. I should have run the AN line directly back to the trans. Hindsight...
  18. #18 Re: Intense Shift kit
    Donating Users EHB's Avatar
    Dec 2014
    Maryland
    Quote Originally Posted by ADecker View Post
    2) remove filter
    4)open accumulator
    5) replace springs
    you just posted it ...lol
    2000 GTP - 3" Catted DP...ZZP Plog...9" Cone filter...Reptile pcm...3.4 pulley...AL104's
  19. #19 Re: Intense Shift kit
    Buffalo
    Quote Originally Posted by Dadkota View Post
    It's quite simple when you think about it. Laying on your back versus leaning over top. It's nothing complicated like the valve body or anything. Literally what you see in the instructions is all you do. Just have brake cleaner to clean the parts, pan and magnet and buy new fluid.
  20. #20 Re: Intense Shift kit
    May 2008
    Schuyler, NE
    It will usually extend the life of your clutch packs. But, it will shorten the life of your input shaft and gear set.
    IMO, cars with your power level have no need for a shift kit, unless they are having trans problems. You can do everything you need to with a tuner.
  1. zzp shift kit or intense shift kit
    By ScammingL67beast in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 10-19-2013, 10:50 PM
  2. Brand new intense shift kit zzp mps 3.5
    By Matt Palm in forum For Sale - Parts
    Last Post: 08-06-2013, 06:17 PM
  3. P0243 and an intense shift pac????
    By Tony in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 04-02-2010, 04:04 PM
  4. Intense shift kit installed
    By Sabrewings in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 02-15-2009, 05:10 PM
  5. Intense shift kit
    By 99prixgt in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 10-26-2008, 02:04 AM
