OP did you ever get it reset? You said you went the local route so did you find a dealer to do it then?
I'm still trying to get to the bottom of exactly how this can be done. Some say it can be done with a tech2. If that's the case then any gm service department would be able to do this. And I don't understand how they can say it's illegal. The mileage it stored in the bcm so unless you asked them to lower the milage below what your bcm shows I don't see any legality issues here. And from my understanding that dic can't be set to an exact milage. A new one will pick up your bcm milage when you plug it in and drive so I'd think if you reset a used one it would have the same outcome. I'm afraid this is what I will run into when I try my local dealer out... I actually considered buying a tech2 if I knew for sure I could reset it on my own but I've been researching this issue for months and still haven't found a definite answer on if the tech2 will do it.
