Thread: New car, old issues..
Results 1 to 10 of 10
jaked1985 New car, old issues.. 05-04-2017, 04:08 PM
WarStryker13 Re: New car, old issues.. 05-04-2017, 04:58 PM
FordMan77 Re: New car, old issues.. 05-04-2017, 05:05 PM
jaked1985 Re: New car, old issues.. 05-04-2017, 06:23 PM
jaked1985 Re: New car, old issues.. 05-04-2017, 07:16 PM
Fivefingerdeathpunch Re: New car, old issues.. 05-04-2017, 08:12 PM
jaked1985 Re: New car, old issues.. 05-04-2017, 09:15 PM
Fivefingerdeathpunch Re: New car, old issues.. 05-04-2017, 10:04 PM
jaked1985 Re: New car, old issues.. 05-05-2017, 12:05 AM
jaked1985 Re: New car, old issues.. 05-08-2017, 10:43 PM
  1. #1 New car, old issues..
    SE Level Member jaked1985's Avatar
    Jan 2012
    West Union, Iowa, United States
    Just picked up an 07 GT for something to keep the miles off my silverado going back and forth to work.
    It's got a few issues, coolant elbows, vc gaskets, a wheel bearing going out, tie rod ect...
    All of which I'm fully capable of diagnosing and repairing. There is one other issue that I'm having trouble nailing down though.
    Cruise control!
    No cruise control on indicator on the dic when I press the button.
    Brake lights work, switch on the column seems to be ok, not really sure how to test it.
    Any ideas?
    I tried to do a search for the topic, but I wasnt able to get anywhere.
    Purple 06 gxp
    Black 99 burb 7.4, 4x4, 4.10s 285s on utlra type 50/51s true duals, no cats, no mufflers
  2. #2 Re: New car, old issues..
    I break things. WarStryker13's Avatar
    Oct 2014
    Frederick, MD
    Check the grounds in the engine bay, that one on the strut tower next to the battery is my first suspect.
    My cruise was very temperamental until I cleaned up that ground point, and then like magic, worked flawlessly.
    Bad grounds can also mess with the magnasteer, ABS, radio, HVAC, lights, horn, the list goes on...
    04 GP GT2: Handling upgrades, go-slow parts, and an attitude. Totaled.
    87 Dodge Ram 50:​ Junkyard rescue, resurrection in progress.
  3. #3 Re: New car, old issues..
    St. Louis
    You say brake lights work, but does the high mount work?
  4. #4 Re: New car, old issues..
    Jan 2012
    Quote Originally Posted by FordMan77 View Post
    Yes, the light in the spoiler is also working.
    Purple 06 gxp
  5. #5 Re: New car, old issues..
    Jan 2012
    I found this while checking grounds/connections.... Dont see anywhere for it to go?
    Purple 06 gxp
  6. #6 Re: New car, old issues..
    Looks like a Cali emissions plug, for the air pump.
    A bad brake light switch can cause the CC not to work, it will allow the brake lights to fully work but it can still be faulty and cause the CC not to work.
  7. #7 Re: New car, old issues..
    Jan 2012
    I ordered a new bls tonight. So, I'll give that a try when it shows up.
    Purple 06 gxp
  8. #8 Re: New car, old issues..
    It's a cheap fix if it works, most are less than $15 bucks.
  9. #9 Re: New car, old issues..
    Jan 2012
    Well, a slight revelation on my way home from work. If I repeatedly press the button on the end of the turn signal switch to set the cruise, the light on the dash will, for a split second, illuminate and the dic flashes cruise control activated. But it won't stay on. So, I'm hopeful that the brake switch will be the fix.
    Purple 06 gxp
  10. #10 Re: New car, old issues..
    Jan 2012
    Just wanted to update.
    The brake switch did not solve the problem. Ended up replacing the multifunction switch on the column. Fixed it! Local advance auto had the switch in stock, so I did site to store, 30% off got me the switch for about $50 aftet tax.
    Thanks for all the input guys!
    Purple 06 gxp
  1. issues
    By porkman33 in forum Introductions/Noob Questions
    Last Post: 05-01-2015, 06:53 AM
  2. key fob issues
    By kyliek23 in forum General Grand Prix Discussion
    Last Post: 01-09-2014, 09:07 PM
  3. KR issues
    By krippled in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-01-2013, 02:17 AM
  4. ABS Issues
    By ljmonnin12 in forum Brakes/Suspension/Chassis
    Last Post: 12-18-2010, 01:13 AM
  5. A few issues
    By Ellen in forum General Tech Discussion
    Last Post: 09-17-2009, 09:29 AM
