Thread: Dealer told me DIC cannot be reprogrammed to show my mileage after 5 button upgrade..
Results 1 to 15 of 15
  1. #1 Re: Dealer told me DIC cannot be reprogrammed to show my mileage after 5 button upgra
    Aug 2015
    Virginia
    I went the local route, ended up costing a little over $100
    Sent from my iPod touch using Tapatalk
  2. #2 Re: Dealer told me DIC cannot be reprogrammed to show my mileage after 5 button upgra
    Sep 2016
    Western ky
    OP did you ever get it reset? You said you went the local route so did you find a dealer to do it then?
    I'm still trying to get to the bottom of exactly how this can be done. Some say it can be done with a tech2. If that's the case then any gm service department would be able to do this. And I don't understand how they can say it's illegal. The mileage it stored in the bcm so unless you asked them to lower the milage below what your bcm shows I don't see any legality issues here. And from my understanding that dic can't be set to an exact milage. A new one will pick up your bcm milage when you plug it in and drive so I'd think if you reset a used one it would have the same outcome. I'm afraid this is what I will run into when I try my local dealer out... I actually considered buying a tech2 if I knew for sure I could reset it on my own but I've been researching this issue for months and still haven't found a definite answer on if the tech2 will do it.
  1. 04+ 3 button to 5 button upgrade
    By Mad Monkey in forum How To Write-Ups/Tech Tips
    Last Post: 08-30-2016, 05:00 PM
  2. How does the DIC's odometer get reprogrammed?
    By April Thompson in forum General Grand Prix Discussion
    Last Post: 01-19-2015, 11:29 AM
  3. How-to: 5 button DIC upgrade (no reprogram necessary) (04+) [*]
    By TyroElite in forum How To Write-Ups/Tech Tips
    Last Post: 06-05-2012, 11:59 PM
  4. Replies: 16
    Last Post: 07-14-2011, 05:44 PM
  5. Does anyone else have this issue after getting a reprogrammed pcm?
    By pontiacgp759 in forum General Tech Discussion
    Last Post: 01-31-2010, 01:40 PM
