Thread: Multiple issues on 04 Grand Prix. Feeling aggrevated.
Results 1 to 13 of 13
  1. #1 Re: Multiple issues on 04 Grand Prix. Feeling aggrevated.
    Nov 2013
    United States
    Okay so here is what I found out today. Put the scanner on and ran it through the engine, ABS, heater, IPC, and airbag side for codes. Lets start with engine. Came up with a C0035 which is the LF wheel speed sensor malfunction. This is what it had before along with a C0245-Wheel speed sensor frequency/EBCM control valve circuit. This one did not come back up. This shows up on the engine and ABS scan. Also have a P0420- Catalyst Efficiency low bank 1. I haven't done hardly any reading on this yet but one place points to possible bad cat convertor. Great. We will see what I can find out on this too.
    Next I scanned the heat and air side of it. Came up with a B0268-= Air flow control 7 circuit short to battery or open. Not sure on this yet. B0269- Air inlet door range error. We will see about this. I should note that daughter has been telling me that the heater has been making a loud noise. So today while I had the scanner on I started the car and ran the heater while waiting on the scanner. It made a couple of loud almost grinding type of noises pretty loud from the area of the blower motor. When this happened it didn't sound like the pitch or speed of the blower changed. Not sure if there is a motor that is trying to change a blend door or what. I switched the mode from defrost to floor to vent and no noises. I also want to say that everytime that the car is started the A/C light is on and you have to shut it off. Even with the heat set it comes on as soon as you turn the key on.
    Then I went into the IPC side of the scan and it showed up with a U1000- Class 2 Data link Fault. On the Air bag side of it there was a code U1096-Lost communication w/IPC/DIC
  1. Multiple Issues 2003 Grand prix 6.1
    By DavisonFam in forum General Tech Discussion
    Last Post: 07-01-2013, 08:17 AM
  2. 1999 Grand Prix multiple issues could it be BCM ??
    By knewbomb in forum General Tech Discussion
    Last Post: 05-29-2012, 02:56 PM
  3. 02 Pontiac Grand Prix GT multiple issues.
    By roush in forum General Tech Discussion
    Last Post: 04-04-2012, 09:28 AM
  4. 2001 Grand Prix GT: possible multiple issues...
    By mdurisseau in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-05-2009, 12:06 PM
  5. 05 gt grand prix Multiple Warning lights
    By later in forum General Tech Discussion
    Last Post: 01-11-2009, 07:46 PM
