Thread: 04 GTP COMP G electrical issue - RESOLVED
Results 1 to 8 of 8
GTX 04 GTP COMP G electrical... 05-02-2013, 12:36 AM
importisland13 Re: 04 gtp comp g odd issue -... 05-02-2013, 12:37 AM
GTX Re: 04 gtp comp g odd issue -... 05-02-2013, 01:28 PM
daltman360 Re: 04 gtp comp g odd issue -... 05-05-2013, 12:20 AM
GTX Re: 04 gtp comp g odd issue -... 05-05-2013, 11:22 PM
matt5112 Re: 04 gtp comp g odd issue -... 05-17-2013, 08:02 PM
GTX Re: 04 gtp comp g odd issue -... 05-18-2013, 12:57 AM
GTX Re: 04 GTP COMP G electrical... 05-17-2013, 07:29 PM
  1. #1 04 GTP COMP G electrical issue - RESOLVED
    GT Level Member GTX's Avatar
    Apr 2008
    Vallejo,Ca
    At first it began with the service ABS/TRACTION/STABILITY and BRAKES on the DIC with the dummy lights for the ABS TRACTION and E-BRAKE lights on the IPC
    Tonight, I had very brief display of service charging system light right before the IPC, HUD,DIC and radio stopped working...all gauges read no values or had no displays/power
    I turned the vehicle off thinking I might reset the issue....the car did not start just heard a relay click, no engine crank and after 7-8 key turns..it fired up and I was on my way...however this did not fix the original issues described in the previous paragraph....now the car only randomly starts and when it does it sounds normal...nothing to suspect charging/battery/fuel...exterior lights, windows, door locks, interior lighting, 12 volt sources all powered...however scanner does not communicate with any of my modules....PCM,BCM etc....
    The key when turned, you will hear clicking from the right side ( passenger side ) as well as the fuel pump priming ...however the chime will not chime ...I'm leaning towards the ignition cylinder....but since this problem happened tonight I have not really jumped into until tomorrow hopefully when I have daylight ....
    Just wondering if anyone has ever had any similar or exact problems as described..
    I have so far checked....battery, battery terminal connections, underhood fuses and relays (swapping and replacing ) as well as the interior which all turned up with no different results...
    If interested I will post video of this situation to give a better idea
    Any help would be beneficial and greatly appreciated , thanks
    edit: heated seats are also inop as well as AC..HVAC system/Blower motor DOES BLOW AIR, air conditioning with the button pressed no longer blows cold
    and of course....Data Link Connector is powered, however scanner will no longer communicate to any module in the car
    COMP G
  2. #2 Re: 04 gtp comp g odd issue - electrical
    Banned
    Jan 2013
    the bandwagon follower aka noobiee
    i get that issue twice a year no clue either might have a short somewhere
  3. #3 Re: 04 gtp comp g odd issue - electrical
    Apr 2008
    Vallejo,Ca
    oddly enough when playing with the IGN 1 relay in the junction block underhood, power is restored to the IPC, HUD, DIC, AC, and radio
    COMP G
  4. #4 Re: 04 gtp comp g odd issue - electrical
    Mar 2013
    Burton,MI
    This happened to me too a while ago. Found out my a/c blower shorted.. Replaced it and starts right up... Grand Prix electrical has always been bad...
  5. #5 Re: 04 gtp comp g odd issue - electrical
    Apr 2008
    Vallejo,Ca
    Quote Originally Posted by daltman360 View Post
    are you suggesting my blower motor shorted out and causing all these problems?
    COMP G
  6. #6 Re: 04 gtp comp g odd issue - electrical
    Quote Originally Posted by GTX View Post
    There's an issue with the wiper motor that causes an issue with the blower motor.
    http://www.justanswer.com/pontiac/61...d-working.html
  7. #7 Re: 04 gtp comp g odd issue - electrical
    Apr 2008
    Vallejo,Ca
    not my problem
    COMP G
  8. #8 Re: 04 GTP COMP G electrical issue - RESOLVED
    Apr 2008
    Vallejo,Ca
    RESOLVED ISSUE ... found short within the EBCM
    COMP G
  1. Possible Electrical Issue??
    By stef in forum General Tech Discussion
    Last Post: 12-27-2012, 12:15 PM
  2. Odd electrical issue
    By SDGTP99 in forum General Grand Prix Discussion
    Last Post: 07-02-2012, 08:01 AM
  3. new electrical issue on 02
    By powdercoater46 in forum General Tech Discussion
    Last Post: 09-02-2011, 05:41 PM
  4. 04 comp g electrical/computer help
    By Billnz28 in forum 04+ Specifics
    Last Post: 02-05-2010, 08:10 PM
  5. electrical issue
    By BoostJunki3 in forum General Tech Discussion
    Last Post: 12-10-2009, 10:49 PM
