Thread: Possible Electrical Issue??
Results 1 to 5 of 5
  1. #1 Possible Electrical Issue??
    SE Level Member stef's Avatar
    Mar 2012
    Wolcott, Indiana, United States
    I have a 1997 Pontiac Grand Prix GT. Recently, the blower for the Heat and A/C will work when it wants to. It will stop working for a while and then all of a sudden come on. The dash lights, the lights on the steering wheel and the switches on the door have gone dim. They will work when I move the switch over. I would like to know if it is a fuse or electrical.
  2. #2 Re: Possible Electrical Issue??
    Nov 2012
    Madison
    probably just need a blower motor..a fairly common problem on GPs
    could have been caused by water leaking from windshield cowl .....might want to check this out http://www.grandprixforums.net/water...-fix-6961.html
  3. #3 Re: Possible Electrical Issue??
    Nov 2011
    NY
    First things first, yes, the water leak issue will destroy the blower motors and sometimes the resistors, but unless you've had water in passenger compartment floorboards thats unlikely the issue. I would start by checking the main ground, negative cable to the battery and where it attaches to the car, look for corrosion, take the cable off and clean around where it seats and use some dialectric grease when reassembling. You can check the alternator connections as well.
    Merry Christmas by the way.
  4. #4 Re: Possible Electrical Issue??
    Mar 2012
    ok i havent seen any water on the floorboard. and my bboyfriend and i checked the connections, and we didnt see anything wrong. is there a fuse that we could look for?
  5. #5 Re: Possible Electrical Issue??
    Yoga city
    blower motor resistor or possible ignition switch seemed to always be the culprit here.
  1. Odd electrical issue
    By SDGTP99 in forum General Grand Prix Discussion
    Last Post: 07-02-2012, 08:01 AM
  2. new electrical issue on 02
    By powdercoater46 in forum General Tech Discussion
    Last Post: 09-02-2011, 05:41 PM
  3. 99 GTP Electrical issue
    By LS1z2800 in forum General Tech Discussion
    Last Post: 05-06-2011, 07:01 PM
  4. electrical issue
    By BoostJunki3 in forum General Tech Discussion
    Last Post: 12-10-2009, 10:49 PM
  5. Electrical Issue...I Think.
    By RicerKiller in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-09-2009, 11:39 AM
