Thread: Factory Remote Start 2005 GTP
Results 1 to 3 of 3
HuffNPuff Factory Remote Start 2005 GTP 12-10-2012, 04:55 PM
HuffNPuff Re: Factory Remote Start 2005... 12-14-2012, 06:49 AM
SlowNA06 Re: Factory Remote Start 2005... 12-14-2012, 08:56 PM
  1. #1 Factory Remote Start 2005 GTP
    SE Level Member HuffNPuff's Avatar
    Nov 2010
    NC
    My 05 GTP is equipped with a factory remote start. Since installing ZZP PCM, I have an odd occurrence with it. There are NO codes. NO security indicators. NO faulty sensors (hood/door/etc). With a fresh battery disconnect, the remote start will work perfectly.... 3 times. After that, nada. I don't mean that it hits is 2-tries/starts limit before having to manually start for a reset. I mean 3 starts... period. Even if I put the key in and manually start the car 100 times in between remote start attempts.
    After 3 remote starts, the subsequent failures happen with the following characteristics: The remote start signal is received. Certain ignition circuits turn on. The fuel pump turns on and primes/pressurizes. But, the starter NEVER engages... does not spin... nada. zip. zilch.
    If I disconnect the battery for 15-20 minutes, then reconnect. The remote start works like a champ again... for 3 more starts. Then, the pattern is repeated.
    Another potentially security/BCM related issues is that I will also get random "LOCKED" and "CALIBRATE" errors on my head unit at startup. They usually flash on screen, then go away within a second or two, with the worst effect being that I have to press the power button (yes, even if it has flashed "LOCKED," it will power off and back on fine.). This is a very random, but frequent occurrence--a few times a week. It may do it 5 times in a day. It may not do it at all for 3-4 days. Sometimes, but by far in the minority, it will stay in LOCKED mode, but will come back and work fine after turning the ignition off and back on.
    Any ideas?
  2. #2 Re: Factory Remote Start 2005 GTP
    Nov 2010
    NC
    bump
  3. #3 Re: Factory Remote Start 2005 GTP
    Pennsylvania
    Might want to give ZZP a call about that.
  1. 12v remote factory 2005 monsoon
    By 05gtpcompG in forum Audio, Security & Visual Electronics
    Last Post: 06-18-2011, 02:50 AM
  2. 2005 gtp with remote start
    By racergurl2007 in forum General Tech Discussion
    Last Post: 12-28-2010, 09:29 PM
  3. Factory Remote Stopped Working
    By mltyplx in forum Audio, Security & Visual Electronics
    Last Post: 12-20-2010, 09:22 PM
