Thread: 2008 Base model plug and plug wire swap
Results 1 to 3 of 3
MS1227 2008 Base model plug and plug... 12-06-2012, 01:01 PM
SlowNA06 Re: 2008 Base model plug and... 12-06-2012, 05:00 PM
nik12937 Re: 2008 Base model plug and... 12-06-2012, 06:14 PM
  1. #1 2008 Base model plug and plug wire swap
    Nov 2008
    Georgia
    Hi all,
    I'm planning on replacing plugs and plug wires on my 08 base model soon and was wondering if anyone had a step by step guide, specifically for the method of removing the dog bones and rocking the engine to get to the rear plugs.
    Thanks!
  2. #2 Re: 2008 Base model plug and plug wire swap
    Pennsylvania
    1. Remove dog bones.
    2. Attach ratchet strap hook to radiator mount and engine bracket.
    3. Crank dat.
    4. Remove a single plug wire from its spark plug.
    5. Remove spark plug.
    6. Replace spark plug with new one.
    7. Remove that spark plug wire and replace with new one that looks just like it.
    8. Repeat steps 3-6 until you run out of spark plugs and wires.
    9. Remove ratchet strap.
    10. Replace dog bones.
    11. Beer.
  3. #3 Re: 2008 Base model plug and plug wire swap
    Pennsylvania, USA
    If the wires are old enough, expect the wires to pull out of the boots/possibly get some bloody knuckles. Dental floss (wrapping it around the plug boot) works well if you get the engine forward enough and can read it decently easy.
  1. PRJ spark plug wire set??
    By TheManInBlack in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-25-2013, 10:21 PM
  2. Spark Plug Wire Routing
    By GTPCHUCKY in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-13-2012, 06:58 PM
  3. spark plug wire help
    By ryanmjw in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-26-2011, 11:34 AM
  4. spark plug wire question
    By copperpacecar in forum General Tech Discussion
    Last Post: 05-12-2010, 12:20 AM
