Thread: replacing steering wheel
Results 1 to 17 of 17
  1. #1 replacing steering wheel
    Jul 2011
    Illinois
    I have the rubber steering wheel in my 08 grand prix. I want to replace it with a leather one. I'm not sure if I want to mess with it if it is too hard to do though. I was wondering if anybody could help me out with how to go about removing the steering wheel. Thanks for any help.
  2. #2 Re: replacing steering wheel
    Pennsylvania
    Quote Originally Posted by joeringo11 View Post
    there's a tutorial floating around on how to paint the steering wheel which should show how to remove some stuff.
  3. #3 Re: replacing steering wheel
    GT Level Member dengnath's Avatar
  4. #4 Re: replacing steering wheel
    Jul 2011
    Illinois
    sweet. thanks guys
  5. #5 Re: replacing steering wheel
    Jul 2011
    Illinois
    alright so I've been trying to get the airbag assembly off for awhile now but I can't get it to release. Does anyone have some pointers because I can't seem to figure it out
  6. #6 Re: replacing steering wheel
    Pennsylvania
    Did you turn the wheel to make it easier on yourself?
  7. #7 Re: replacing steering wheel
    Jul 2011
    Illinois
    ya I just couldn't seem to move the bar. I went to the junk yard today and found a leather steering wheel without the airbag. I tried getting it off but it wouldn't budge. I had all the bolts loose but it just seemed like it was still attached some how. Does anyone know of a video on this?
  8. #8 Re: replacing steering wheel
    Pennsylvania
    It's like harpooned into the steering wheel. You've got to like jimmy it out. That tutorial pretty much covered it. A movie would be awesome, but you'd have to use one of those little cameras with the lights on it that they like... inspect urethrae with. Just showing a guy puking a wire into his steering wheel probably isn't much help.
  9. #9 Re: replacing steering wheel
    Jul 2011
    Illinois
    haha good point. and to remove the steering wheel you have to use this special tool to pop it off i found out.
  10. #10 Re: replacing steering wheel
  11. #11 Re: replacing steering wheel
    Jul 2011
    Illinois
    That was my other option. Was it hard to do the stitching?
  12. #12 Re: replacing steering wheel
    nope took about 15 mins and I was done
  13. #13 Re: replacing steering wheel
    Kansas
    It's pretty simple. I've done it numerous times. Turn your wheel about 90 degrees, take a small flat screwdriver. Slide it into one of the holes, feel it catch, then rotate the screwdriver. Should release, then do the one on the same side, then do the other two. Make sure you hold up on the side you already removed.
  14. #14 Re: replacing steering wheel
    Jul 2011
    Illinois
    alright I'll try it again sometime but if I can't get it then I'll probably just go with the wheelskinz
  15. #15 Re: replacing steering wheel
    London Ont, Canada
    Sub'd to thread, need to post so i can find it easier lol
  16. #16 Re: replacing steering wheel
    Mar 2012
    NC
    There's a subscribe option for that. LOL
  17. #17 Re: replacing steering wheel
    wow it come off just like a regal's air bag. i didnt have them right angle screw driver things, so i used the bit from one of them screw drivers that has a small and large philips or flat on either side and a pair of vise grips to hold the bit.
    pop one open, hold it up, then pop the one under it so one side is up, then do the other side. if you dont keep a steady up pull they like to lock up again real fast on you.
    you have a few wires to deal with so dont just rip it off. and un plug the battery first.
  1. Replacing Power Steering Pump
    By AGP in forum General Tech Discussion
    Last Post: 07-11-2013, 05:30 PM
  2. Steering Wheel with LED
    By jcl1 in forum Visual/Body Modifications
    Last Post: 10-25-2009, 10:35 AM
  3. replacing lights in steering wheel controls
    By 68galaxie500 in forum Audio, Security & Visual Electronics
    Last Post: 08-19-2009, 08:08 PM
  4. Replacing wheel bearing
    By robahr24 in forum Brakes/Suspension/Chassis
    Last Post: 11-11-2008, 03:51 AM
