Thread: replacing steering wheel
Results 1 to 17 of 17
  1. #1 Re: replacing steering wheel
    Kansas
    It's pretty simple. I've done it numerous times. Turn your wheel about 90 degrees, take a small flat screwdriver. Slide it into one of the holes, feel it catch, then rotate the screwdriver. Should release, then do the one on the same side, then do the other two. Make sure you hold up on the side you already removed.
  2. #2 Re: replacing steering wheel
    Jul 2011
    Illinois
    alright I'll try it again sometime but if I can't get it then I'll probably just go with the wheelskinz
  1. Replacing Power Steering Pump
    By AGP in forum General Tech Discussion
    Last Post: 07-11-2013, 05:30 PM
  2. Steering Wheel with LED
    By jcl1 in forum Visual/Body Modifications
    Last Post: 10-25-2009, 10:35 AM
  3. replacing lights in steering wheel controls
    By 68galaxie500 in forum Audio, Security & Visual Electronics
    Last Post: 08-19-2009, 08:08 PM
  4. Replacing wheel bearing
    By robahr24 in forum Brakes/Suspension/Chassis
    Last Post: 11-11-2008, 03:51 AM
