Quote Originally Posted by PonchoDvr4Lfe View Post
1.)You do not need to recalibrate anything your HUD. The return spring on the mirror broke. Look in the how-to for directions on how to fix. There are twenty threads on it.
2.)Could be several things with the window, tear ur door apart and look around.
3.)If you are audacious enough you could replace the bulbs in the deck urself. But then you would need to unlock it for the car again. (ie: theftlock or whatever it is called)
If you do open the deck and do it yourself, go into your DIC and change the theftlock off. Then you wont have to reset the lock to make your radio work again. First you turn it off, then you have to disconnect the battery so that it does not detect the removal of the deck.
