Thread: Problems with my 04 GP
Results 1 to 7 of 7
04gpking85 Problems with my 04 GP 05-24-2009, 05:17 PM
04GTPCOMPG Re: Problems with my 04 GP 08-15-2009, 09:26 AM
Panther427 Re: Problems with my 04 GP 08-15-2009, 10:44 AM
04srmGTP Re: Problems with my 04 GP 10-14-2009, 12:11 PM
PonchoDvr4Lfe Re: Problems with my 04 GP 10-15-2009, 12:45 PM
04GTPCOMPG Re: Problems with my 04 GP 10-17-2009, 02:15 PM
reveregtp Re: Problems with my 04 GP 10-15-2009, 12:55 PM
  1. #1 Problems with my 04 GP
    Chicago, IL
    So I have a few problems with my '04 GP and was wondering if I could get some help. First off my drivers and passengers front windows squeak when they go down and sometimes they don't go down at all. Is this something I can fix myself and if so what do I do? Secondly I have the 6 disc stock cd player and the buttons on the right don't light up but the rest of the buttons do, could it be a fuse or what do I need to do? Thirdly, and last, my hud won't go down when I try to adjust it, is their any way I can fix it on my own or do I need to take it to the dealer? Any help would be great, thanks.
    MSD Ignition Coils, K&N CAI, SLP Headers/Downpipe/High Flo Cat/Cat Back Exhaust, Overkill PCM, 20" Moda Rims
  2. #2 Re: Problems with my 04 GP
    SE Level Member 04GTPCOMPG's Avatar
    Apr 2009
    MA
    *This is an assumption*
    I worked on the HUD in the F18 when I was in the navy and we needed special calibration tools to realign the screens. I'm assuming these are the same way as a HUD is a HUD and the dealer would have to do this.
  3. #3 Re: Problems with my 04 GP
    GTX Level Member Panther427's Avatar
    Dec 2008
    colorado
    For your squeaky windows. A weather stripping lubricate on the seals around the windows
  4. #4 Re: Problems with my 04 GP
    Feb 2009
    For your lights on the radio try hitting the dash by the radio and they should come back on. If this doesn't work then they a burnt out and need replacing.
  5. #5 Re: Problems with my 04 GP
    Donating Users PonchoDvr4Lfe's Avatar
    Feb 2008
    Kent, OH
    1.)You do not need to recalibrate anything your HUD. The return spring on the mirror broke. Look in the how-to for directions on how to fix. There are twenty threads on it.
    2.)Could be several things with the window, tear ur door apart and look around.
    3.)If you are audacious enough you could replace the bulbs in the deck urself. But then you would need to unlock it for the car again. (ie: theftlock or whatever it is called)
    04' GP GTP Comp G, 08' G8 GT, 10' Camaro 2SS
  6. #6 Re: Problems with my 04 GP
    Apr 2009
    MA
    Quote Originally Posted by PonchoDvr4Lfe View Post
    If you do open the deck and do it yourself, go into your DIC and change the theftlock off. Then you wont have to reset the lock to make your radio work again. First you turn it off, then you have to disconnect the battery so that it does not detect the removal of the deck.
  7. #7 Re: Problems with my 04 GP
    SE Level Member reveregtp's Avatar
    Nov 2008
    Revere, MA
    first thing i would do is grab some carbon powder and put it along the sides of the window (where it slide up and down within the watherstripping)
  1. 2 problems need help with
    By kenneth74gt in forum General Tech Discussion
    Last Post: 04-19-2009, 02:21 AM
  2. 01 GT problems
    By Baumku in forum General Tech Discussion
    Last Post: 04-06-2009, 10:45 PM
  3. some problems
    By EmEaston24 in forum General Tech Discussion
    Last Post: 09-23-2008, 06:28 PM
  4. cam problems
    By boredout in forum 3.1L V6 (LHO/LG8)
    Last Post: 07-05-2008, 06:59 PM
  5. Many problems/ Please help
    By Vurelis in forum General Tech Discussion
    Last Post: 06-15-2008, 03:45 PM
