Thread: fog light help
Results 1 to 9 of 9
  1. #1 fog light help
    Jan 2009
    ga
    I'm not sure what dirrection I need to go. I would like to black out my headlights and taillights, I know that light transmision would be partially blocked with the headlights so I think I need to swap out my foglights for more powerful ones. The problem is that I have a 08 grandprix and there are also turn signal/parking lights in the fog housings. What should I do?
    Thank you all in advance,
    ~Drew
  2. #2 Re: fog light help
    GT Level Member Clar2478's Avatar
    Nov 2008
    Idaho
    change the bulbs for the foglights, the bulbs are separate.
    Call me Brad
    '06 GT: Just a few mods here and there.
  3. #3 Re: fog light help
    GTX Level Member Warhellride's Avatar
    Norfolk, VA; originally from NH
    Your foglights aren't going to be a replacement for your headlights no matter what bulbs you put in them. They're not designed to have the same beam pattern as your headlights.
    Your best option would be to upgrade your headlights to HID's.
    2004 Mercedes-Benz CL55 AMG
    2002 Redfire Metallic Grand Prix GT Coupe (sold after 141,754 miles)
  4. #4 Re: fog light help
    Jan 2009
    ga
    thats what I was afraid of. I figured if i just changed the bulbs and not the housing I would mely the fog housings.
    Are we sure if i upgrade the actual headlights they would be bright enough?
    If I just kept the brights on all the time would that be enough to safely frive with?
    If that is the case how exactly do I keep the fogs on with the high beams?
    Thanks
  5. #5 Re: fog light help
    Nov 2008
    Idaho
    you shouldn't have to use your brights if you go with HID's as your low beams. my heads, tails, and fogs are all tinted with HID's and I don't have a problem with seeing. mine are still brighter than they were untinted with halogens
    Call me Brad
  6. #6 Re: fog light help
    SE Level Member Slueth66's Avatar
    Nov 2008
    Iowa
    Whats the easiest way to replace your foglights? just jack the car up or removing the bumper?
  7. #7 Re: fog light help
    Nov 2008
    Idaho
    i've got an '06 and unless they changed the way they're installed, there should jsut be two screws right on the front of the lense of each foglight and the whole housing should just pull out.
    Call me Brad
  8. #8 Re: fog light help
    Nov 2008
    Iowa
    Anyone know if an 01 is similar?
  9. #9 Re: fog light help
    May 2008
    McHenry IL
    2 bolts on 01's on the top of te headlight assemble piece of cake
  1. oil light
    By beto6169 in forum General Tech Discussion
    Last Post: 04-27-2009, 11:10 AM
  2. ABS/TCS Light
    By TCO in forum General Tech Discussion
    Last Post: 01-18-2009, 02:41 AM
  3. ZZP dp & SES light
    By TheOtherNick in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-08-2008, 01:47 PM
  4. help... my ses light is on
    By kingd44 in forum General Tech Discussion
    Last Post: 03-07-2008, 09:45 PM
  5. Head Light/Tail Light Covers
    By datApocalypse in forum Visual/Body Modifications
    Last Post: 01-30-2008, 11:38 PM
