Thread: Hid with a high beam
Results 1 to 15 of 15
  1. #1 Hid with a high beam
    Nov 2008
    Cedar Rapids, IA
    Hey guys, before the flaming starts I have searched quite exhaustively on this topic. I have been debating going to HID for a while now but I do a lot of interstate night driving as well as back roads here in IA and it would be nice to have a kit that produces a USABLE high beam whether it be hid or not. Does anyone have suggestions of a kit that works? More importantly has anyone actually TRIED any of these kits? All your help is greatly appreciated. Thanks!!
  2. #2 Re: Hid with a high beam
    you arent going to find a HID kit that has a useable high beam unless you look into projectors.
    i have a bi-xenon kit that has two filaments in each bulb. the high beam is fairly useless and im pretty sure both of my high beams have burned out now. now i only have regular headlights anyway.
  3. #3 Re: Hid with a high beam
    GTX Level Member Warhellride's Avatar
    Norfolk, VA; originally from NH
    ***Ultimate HID Thread***
    Stickied at the top of this page. There's a lot of good information in there, and the general gist is that there are no HID low/high setups for 9007 that will produce an acceptable beam pattern.
    Here are your options:
    2004 Mercedes-Benz CL55 AMG
    2002 Redfire Metallic Grand Prix GT Coupe (sold after 141,754 miles)
  4. #4 Re: Hid with a high beam
    GTP Level Member 99gpse's Avatar
    Dec 2008
    Freeman, SD.
    you could do a TL retrofit.. the TL seem to be the best Bi-Xenon kit out there.. you can usually find them on ebay with HIDs for like $200
    '90 Acura Legend LS V6 2.7 5MT ^
    '87 Acura Legend V6 2.5 5MT
    '94 Saab 900 SE V6 2.5 4AT
  5. #5 Re: Hid with a high beam
    SE Level Member Berger's Avatar
    Feb 2008
    New Philadelphia, Ohio
    I know most people will tell you that you wont get any usable light output from hid highs but out of the ones that tell you that how many have accually used a bi-xenon kit? I have a bi-xenon kit that I bought from a member here (he bought from 3bspecialties) and I can see amazingly well at night with my high beems on. I drive the highway everyday to work at 5am when the only light on the road is what comes from my headlights. I will tell you from personal experiance get them, there worth it, spend the money and you will never regret it. Just dont get e-bay ones the quality from 3b and e-bay are night and day and I believe thats why the ones I have work so well.
    2003 Grand Prix SE / Redfire Metallic
    GT/GTP body conversion - 3"FWI - 56mm TB - AGX/SSC combo - 077's - GMPP front/rear sway bars - GMPP trailing arms - GMPP front/rear STB with DR brackets - 03 Limited Edition spoiler - 12" Front Brakes
  6. #6 Re: Hid with a high beam
    i have a bi-xenon kit as well. when you turn the highs on it is like removing the reflective part from a flashlight and just using the bulb as light. brighter with a wider angle? yup. is it useable in any way? i can sure see the leaves on the trees above me, but the road is not all that good. i usually turn them back to the low beams and they work better.
    do they work? yes. do they work well. no.
  7. #7 Re: Hid with a high beam
    Nov 2008
    Cedar Rapids, IA
    Hmm. Bio, you do hold a good point. And I was debating making my own with the s2000 projector but I don't have nearly enough down time for that. Berger is there any way you can post up some pics of your setup?
  8. #8 Re: Hid with a high beam
    Feb 2008
    I will have to take some first, But I will do that as soon as I can. Probably Thursday morning on my way to work.
  9. #9 Re: Hid with a high beam
    Nov 2008
    Cedar Rapids, IA
    Sounds good, post em up when you can. I looked into retrofit kits again today. It really looks like the best option but at $330 for the kit alone, sheesh...
  10. #10 Re: Hid with a high beam
    Jersey
    I have the 9007 kit from zzp, its just HID lows and halogen highs. All i did was point the headlights up, in combo with my blazertech fogs makes everything light up, it makes high beams useless.
    16' wrx sti- stock
  11. #11 Re: Hid with a high beam
    Nov 2008
    Cedar Rapids, IA
    I have heard some people claim they don't even need highs anymore but with the deer population around here I'd really like to keep my highs haha
  12. #12 Re: Hid with a high beam
    Dec 2008
    Freeman, SD.
    S2k are low beam only. they are also the exact same as TSX. if you want to retain hight beams, use some TL Bi-Xenon's or even Infiniti FX 35/45 seem to be ok too. best projectors out there imo are TSX for low, and TL for low/high
    here is the output from a stock TSX
    here is the low beam from a TL
    and the TL high beam
    this is FX 35/45 output
    low beam, its good
    high beam, not nearly as good as TL
  13. #13 Re: Hid with a high beam
    Nov 2008
    Cedar Rapids, IA
    I really would be willing to create a rockin diy retrofit guide if someone is willing to buy me the kit!!
  14. #14 Re: Hid with a high beam
    Dec 2008
    Freeman, SD.
    LOL i have a couple of projectors laying around.... but they are fogs from a 97 LHS.. lol
  15. #15 Re: Hid with a high beam
    Nov 2008
    Cedar Rapids, IA
    Thanks for all the help guys, I think for now I will run those Philips halogen bulbs. I really am interested in doing a retrofit, guess I'll start saving :-/
  1. New HIDs installed and High Beam/Low Beam issue CORRECTED!!! Woot!
    By GeddyLee in forum General Tech Discussion
    Last Post: 01-29-2009, 07:26 PM
  2. 04+ DRL and High/Low beam wiring
    By ponyfool in forum Visual/Body Modifications
    Last Post: 12-01-2008, 02:31 PM
  3. upgrade for headlights on 96 gp coupe sealed beam
    By graham96gpse in forum Visual/Body Modifications
    Last Post: 10-01-2008, 07:28 PM
  4. HID high beam question.
    By Nabster in forum Visual/Body Modifications
    Last Post: 04-15-2008, 05:26 AM
  5. HID Kits -- dual beam or retractable?
    By Toasty in forum General Tech Discussion
    Last Post: 01-20-2008, 02:00 PM
