Thread: LED Headlights??
Results 1 to 9 of 9
  1. #1 LED Headlights??
    SE Level Member illtacticz's Avatar
    Dec 2010
    Columbus, Ohio
    I want to upgrade my stock lights to LEDs for the time being until I get my retrofits done. Whats the best option right now for a quick LED swap from the stock lights to LEDs?
    I've see a bunch of things out there for 9006 LEDs on Ebay / Amazon, but some reviews are good, others are bad. What are you running and where can I get them?
  2. #2 Re: LED Headlights??
    Jul 2012
    Chicago
    They are all garbage… Think PNP HID garbage.
    -Carl
  3. #3 Re: LED Headlights??
    Quote Originally Posted by nos4blood70 View Post
    This
    Keep the stock halogens until you can finish your retro
    04 Comp G.
  4. #4 Re: LED Headlights??
    Nov 2012
    Madison
    To go against the grain of all the purists, I'ld just run some 9006 HIDs(for 04+ or whatever your car takes) with your new ballasts until you get them done.
    If your spending, hid bulbs are cheap.
  5. #5 Re: LED Headlights??
    Dec 2010
    Columbus, Ohio
    Fasho..Thanks
  6. #6 Re: LED Headlights??
    Dec 2010
    Columbus, Ohio
    Fasho..Thanks
  7. #7 Re: LED Headlights??
    May 2008
    Winnipeg, MB
    I'm running LED 9006 and rather like them over halogen as they give off a much nicer white color then the awful yellow that halogen are. My only gripe is the output is terrible compared to halogen for some reason. Now I am wondering if I were to remove the 'diffuser' thing in front of the bulb that is blocking the light if that will help things because the LED have a mini projector in them that is being blocked by this 'diffuser' inside the headlight assembly.
    2007 Pontiac Grand Prix
  8. #8 Re: LED Headlights??
    Nov 2012
    Madison
    Quote Originally Posted by tod1d View Post
    Sure.
    and as long as you go thru the process of baking, opening and sealing the headlights......put some projectors in.
  9. #9 Re: LED Headlights??
    LEDs create a brighter, more pure light with much, much less depth. up close they light everything up, but anywhere farther out on the beam pattern the light dissipates super fast.
    that's why there aren't many good options for LED headlights unless you spend an absolute fortune on setting them up properly.
  1. No headlights or dash lights when the headlights are turned on. HELP!
    By steeck1 in forum Audio, Security & Visual Electronics
    Last Post: 06-23-2012, 12:08 PM
  2. What headlights to get
    By KwazrollinZ28GTP in forum Visual/Body Modifications
    Last Post: 04-16-2011, 05:00 AM
  3. Headlights?
    By jimmywindle2012 in forum Introductions/Noob Questions
    Last Post: 02-17-2011, 11:26 PM
  4. New headlights
    By ERballa238 in forum Introductions/Noob Questions
    Last Post: 02-16-2011, 03:43 AM
  5. headlights
    By GTP Ryan in forum Off Topic Discussion
    Last Post: 01-17-2011, 09:32 PM
