Thread: Coil pack in the way after runing fuel size IC and supercharger belt? TRY THIS
Results 1 to 6 of 6
  1. #1 Coil pack in the way after runing fuel size IC and supercharger belt? TRY THIS
    GT Level Member Hardonyomom's Avatar
    aurora
    So i just ran into a problem after installing my full size intercooler. I noticed that when i put on the supercharger belt , the clearance was off and it was rubbing against the coil pack. After thinking about it , i tried adding washers to create clearance. Well that didnt work. Then i saw a thread from Billboost where you can took off the plate and cut it down and relocate holes. I thought about it, but i decided to give one more go at the washers idea. There are two bottom holes and one top hole. All you have to do is stack washers on the top hole to give it an angle and just leave the two bottom ones normal. I was weary of this at first but it is actually on there pretty damn tight and has good clearance now.
    F body Front, GXP rear brakes, SSC, Poly Dogbones, SLP Gen 1 spoiler, Gpo's, GTX hood, SD Air dam, LED tails, badges and decals, Comp G Seats,
    FSIC, Ported and painted Gen 3, ZZP LIM, SD Headers, REmoddified ZZP fuel rail, 60 lb injectors, LS7 lifters, 1.9 modded rockers, 2.6 pulley E85, 21 degrees timing -Timboku tuned
  2. #2 Re: Coil pack in the way after runing fuel size IC and supercharger belt? TRY THIS
    BrokeButRuns BadAssGTP02's Avatar
    Jul 2011
    Mass.
    sooooo proud!!!! lol
    Drunkie----- vtec = where 1 million unicorns fart at the same time at 5,500 rpms for extra powah
    Hardgainer-- yours looks nice and tight when I take a picture of mine it sags down..
    Me-- that's what she said lmao
  3. #3 Re: Coil pack in the way after runing fuel size IC and supercharger belt? TRY THIS
    Dec 2013
    ohio
    Just went through the same thing. I notched the plate under coil packs and put (spacers) thick washers under one side of coils. If you want pics PM me your number. Djudge1970
  4. #4 Re: Coil pack in the way after runing fuel size IC and supercharger belt? TRY THIS
    Jul 2014
    colorado
    Relocate them to the firewall!
    Although I just bought the car that way
  5. #5 Re: Coil pack in the way after runing fuel size IC and supercharger belt? TRY THIS
    Anthony Smiths car? That red coupe is damn nice!
  6. #6 Re: Coil pack in the way after runing fuel size IC and supercharger belt? TRY THIS
  1. coil pack
    By kenconerly in forum General Grand Prix Discussion
    Last Post: 11-18-2012, 02:57 PM
  2. Supercharger Belt size
    By xsvtank in forum General Tech Discussion
    Last Post: 10-22-2010, 09:15 PM
  3. coil pack
    By chancinit666 in forum General Tech Discussion
    Last Post: 06-13-2010, 12:22 AM
  4. Fuel Pump? Coil Pack?
    By JoshMcMadMac in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-02-2009, 04:59 PM
