So I saw in the visual looks questions sticky about de badging but the link doesn't work! What badges are typically removed or moved to other locations. Also this is for a GTP
Remove or move w/e badges you want to move.. You don't need someone telling you what to remove or where to relocate them.
In the sticky it mentioned the ones that look the best to remove and I would rather see it without trial and error. So just getting others opinions will help me
Before side debadge
After side debadge
Before trunk debadge
After trunk debadge (and some sexy tips)
The way I've always done mine is with some fishing line, or a steel leader (works faster) Pull it in a sawing motion with it behind the badge, and it'll zip right through the double sided foam-tape. Then use a heat gun and your finger nails to get the rest off. Any residual stuff can be removed with Goo-gone (or similar) Then use a good rubbing compound and a polish to get rid of the outline left.
Thanks guys
