I started to debadge my GP on the trunk lid. Is is supposed to take 20-30 minutes?? I am using fishing line to cut off the badge and using adheseive remover to remove the glue. Is there somthiing else i am missing or am i good?
I just use my man hands and pull really hard lol
Use a hair dryer.. A heat gun can get hot enough to harm the paint...
I used a hair dryer and some fishing line... Went pretty quick.. Then after it came off I used rubbing alcohol and got all the adhesive off. Then I waxed the BAjesus outta it.
Its about the same. I used goo gone.
I'll tell you the easiest way. It took me 5 minutes per badge. All you need, is a hair drier, floss and polishing compound. Heat the thing up for a minute or two, take floss, cut the glue, take polish while glue is still warm and micro fiber towel, BAM. All gone and all done. Easy peasy. Results speak for themselves.
spray wd40 on the adhesive and let set for like 30 sec then it will wipe right off. I have done it a bunch, and works everytime on any decal or sticker. Just make sure when your done rinse it wit soapy water to get off the wd40
razor blade and a steady hand.
