Thread: Headlight Gap
Results 1 to 4 of 4
  1. #1 Headlight Gap
    GT Level Member Madness's Avatar
    Nov 2009
    A little late
    I put new headlight bulbs in a few days ago. I had a hard time getting the assembly to "look right" when I put the headlight back in. I can stick my finger above the light and under the hood on the drivers side. What am I doing wrong?
    Favorite Quote: You can't fix stupid!!
    http://www.youtube.com/watch?v=0gxKStPXyn8
  2. #2 Re: Headlight Gap
    Both plastic tabs on the headlight are inside the metal bracket right??
    Otherwise alot of cars have that gap, low quality design.
  3. #3 Re: Headlight Gap
    GTX Level Member SomeDudeAtHome's Avatar
    Buffalo, NY
    Picture? You only replaced the bulbs and now you have a big gap? I'd compare it to the other side and see if anything looks different. If not then there's adjusters for aiming them. Maybe something got knocked out of place while working on them.
    Black 98 GT bought in summer of 2009 w/28K miles- GTX Rims, Retrofit headlights, tinted tails, 20% tint all around, KYB Excel-G's, WBS Lowering Springs, 33mm Dorman front sway bar, 22mm Addco rear sway bar, BMR trailing arms, BMR STBs front and rear, ZZP control arms, Poly motor mounts, ZZP CAI, Thrasher shift kit
  4. #4 Re: Headlight Gap
    Nov 2009
    A little late
    The gap was there before, but I could not get the assembly back in so it "looked right". Still can't seem to see $hit to the sides, but I can see better forward with the new BP9007SL2's I got from Napa. They replaced some Phillips Crystalvisions?
  1. My headlight retro will beat up your headlight retro
    By 2003 SSEi in forum Visual/Body Modifications
    Last Post: 05-16-2013, 02:49 PM
  2. headlight
    By kawasakidrivinghick in forum General Tech Discussion
    Last Post: 10-26-2011, 08:27 PM
  3. Two Morimoto projectors one cup...uh...I mean headlight...headlight
    By RedDawnGXP in forum Visual/Body Modifications
    Last Post: 03-23-2011, 05:07 PM
  4. DRL headlight help..
    By singularity in forum Audio, Security & Visual Electronics
    Last Post: 09-02-2009, 02:29 AM
