Thread: Boost gauge install help
Results 1 to 17 of 17
  1. #1 Boost gauge install help
    SE Level Member rhenuset's Avatar
    winnipeg
    I got a glowshift 7 colour boost gauge and I have the wires hooked up and installed the vacuum hose to meet up with the factory hose right before the map sensor (map sensor is still connected and works fine). When the engine is running the boost gauge goes into the in/HG section of the gauge. Now I have no experience with boost gauges so is this normal? I thought it should be on the psi side.
  2. #2 Re: Boost gauge install help
    Never Be A Tim. ILoveAudi's Avatar
    Aug 2012
    Middle of Nowhere, OH
    You're almost never going to boost. Unless your foot is on the floor. You will almost always run vacuum, like 99% of the time lol.
    1998 GTP Coupe - DIY Intake, Stock - 178k miles with rusty weight reduction (sold)
    1998 GTP Sedan - CT turbo kit, billet wheel pt61, s1x blower cam, Iceman stage 3 heads, 90# springs for all the valve floatz, walbro pump, fuel pump rewire *slowest s1x build ever*
  3. #3 Re: Boost gauge install help
    winnipeg
    Ok well thanks for clearing that up. Other than that tho its ok if I have the vacuum hose connected right before the map sensor?
  4. #4 Re: Boost gauge install help
    Aug 2012
    If you're getting boost/vac then there shouldn't be a problem. Just curious, how much vac are you seeing at idle?
  5. #5 Re: Boost gauge install help
    winnipeg
    18 inHG. Havent gone for a rip yet so not sure what it is under wot.
  6. #6 Re: Boost gauge install help
    Aug 2012
    That's good. That's normal range.
  7. #7 Re: Boost gauge install help
    winnipeg
    I have read stock boost is usually about 6psi or so? Only engine mod I have is an open cone so I assume it would be around 6psi?
  8. #8 Re: Boost gauge install help
    Florida
    Youre a gen v like me so stock should be more like 7-8. I made 8 psi on stock pulley.
  9. #9 Re: Boost gauge install help
    winnipeg
    Ok well thats all the help I need for this tread so thanks guys. Kinda off topic but dmahlikGT is your plog, dp and thrush a nice loud system over stock (any drone) and for the money are they good power adders?
  10. #10 Re: Boost gauge install help
    Jul 2010
    Coquitlam,BC,Canada
    Quote Originally Posted by rhenuset View Post
    Why don't people just rev the engine in the driveway to test a boost gauge?
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  11. #11 Re: Boost gauge install help
    Quote Originally Posted by Bronco Boy View Post
    Because you can't. No load, no boost.
  12. #12 Re: Boost gauge install help
    Jul 2010
    Coquitlam,BC,Canada
    What? Load? What? So you can't spin the charger faster by revving the engine? Must be something new. LOL
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  13. #13 Re: Boost gauge install help
    Florida
    @rhe my exhaust sounds decent for the most part. At idle its actually a bit quiet except on cold starts which i like cuz car rumbles nicely and sounds twice as loud then when its warm lol but louder then stock and there's a small amount of drone when cruising but.not bad. At wot my exhaust does get a bit loud but not overly loud. As for power my plog and dp combo definitely gave the car some power mainly in the top end. It pulls hard to 90 then slows a bit,i need to get a full tune though.
  14. #14 Re: Boost gauge install help
    Lifer h0wl0ngcanitbe's Avatar
    Marysville WA
    OP your good I just did mine for the first time and im seeing the same things, our rides are not as BA as we would like to think of them. When I let er rip on the freeway I can almost ping it about 7-8 but im a little modded.
    2001 4dr Black GTP Stock and staying that was... maybe
    1997 2dr Black GTP Open Cone, GXP Rims, Black Headlights, ZZP Headers, ZZP Cat Back, Bunch of suspension parts from ZZP, ZZP 10.5MM plug wires, Autolite 605s, Overkill Tune
  15. #15 Re: Boost gauge install help
    There's a bypass valve. However if you rev it..you'll see boost.
  16. #16 Re: Boost gauge install help
    not the boost you should see WOT out on the street. it'll only be a few pounds.
  17. #17 Re: Boost gauge install help
    It'll show something. Now go deal with your issues Cheezyguy.
  1. help me install my boost gauge!
    By des19 in forum General Tech Discussion
    Last Post: 08-22-2012, 06:01 AM
  2. boost gauge install questions!
    Last Post: 08-14-2012, 11:33 PM
  3. boost gauge install questions!
    By des19 in forum General Grand Prix Discussion
    Last Post: 08-12-2012, 06:06 PM
  4. boost gauge install
    By a98gtp4u in forum General Tech Discussion
    Last Post: 10-21-2009, 03:11 PM
