Thread: instrument cluster LED's
Results 1 to 11 of 11
01GT guy instrument cluster LED's 10-15-2013, 09:48 PM
Jake U Re: instrument cluster LED's 10-19-2013, 07:11 PM
The Guz Re: instrument cluster LED's 10-21-2013, 10:19 AM
triebenbach07 Re: instrument cluster LED's 10-21-2013, 11:55 AM
triebenbach07 Re: instrument cluster LED's 10-21-2013, 11:56 AM
01GT guy Re: instrument cluster LED's 10-21-2013, 01:57 PM
triebenbach07 Re: instrument cluster LED's 10-21-2013, 04:19 PM
triebenbach07 Re: instrument cluster LED's 10-21-2013, 04:18 PM
triebenbach07 Re: instrument cluster LED's 10-21-2013, 04:24 PM
01GT guy Re: instrument cluster LED's 10-22-2013, 07:27 AM
triebenbach07 Re: instrument cluster LED's 10-22-2013, 08:12 AM
  1. #1 instrument cluster LED's
    Jun 2013
    I was just curious what type/model of led lights will fit in my instrument cluster. I know too that you have to get rid of the red film before you can even see the blue light. I was also wondering if you simply take off the instrument cluster, take the old lights out and just plug the new blue LED's in.
  2. #2 Re: instrument cluster LED's
    SE Level Member Jake U's Avatar
    Apr 2013
    Waukesha, WI
    I ordered some different colored guage faces. I hope they come in next week. The website had instructions for taking apart the guage cluster. I will post a link to them.
    http://www.pfyc.com/supportfiles/gp2023install.pdf
  3. #3 Re: instrument cluster LED's
    Dec 2008
    Lawndale, CA
    I have seen these being used in clusters over on an f-body forum that I'm a member of.
    http://www.superbrightleds.com/morei...edge-base/853/
  4. #4 Re: instrument cluster LED's
    Donating Users triebenbach07's Avatar
    Dec 2010
    long prairie, mn
    Quote Originally Posted by The Guz View Post
    If you remove the red film, these create nasty hot spots.
    what i did was remove the red film and retrofit several sections of LED strip. I will try and get a picture of the finished product later.
    02 sedan, top swap
  5. #5 Re: instrument cluster LED's
    Dec 2010
    long prairie, mn
    the picure makes it look much worse than it is. Everything is a fairly even intensity.
    02 sedan, top swap
  6. #6 Re: instrument cluster LED's
    Jun 2013
    Quote Originally Posted by triebenbach07 View Post
    so im assuming you just got some of the basic strip led's with sticky backing and stuck them on the gauge cluster back? and do you have a picture of how you positioned the led's? also, was is labor intensive, or is it something i could do in like 4-5 hours.
  7. #7 Re: instrument cluster LED's
    Dec 2010
    long prairie, mn
    ...yeah, 3ish hours
    02 sedan, top swap
  8. #8 Re: instrument cluster LED's
    Dec 2010
    long prairie, mn
    I ordered the 5 meter roll from Amazon. Yes, it has an adhesive back. It's a bit labor intensive, but very doable. I have all of these strips powered from a single twist-in plug from the gauge housing. I also put in a 470 resistor to dim it down a bit when I redid it. It used to be stupid bright. I'll see what I have for pictures of the cluster guts.
    02 sedan, top swap
  9. #9 Re: instrument cluster LED's
    Dec 2010
    long prairie, mn
    I don't know what color you are converting to, but this is what I used.
    http://www.amazon.com/gp/product/B00...?ie=UTF8&psc=1
    02 sedan, top swap
  10. #10 Re: instrument cluster LED's
    Jun 2013
    Thanks! I want to do blue as well, does that amazon product come with the resistors? and thanks for the info on how to do it.
    + Reply to Thread
  11. #11 Re: instrument cluster LED's
    Dec 2010
    long prairie, mn
    the resistors are built in to this item, you can hook it up directly to 12 volt. However, I found this to be way too bright compared to the rest of my interior lights so I added the additional resistor mentioned above. You may acquire it from the Rat Shack.
    02 sedan, top swap
  1. ? About Instrument Cluster
    By KoldAsIce in forum Visual/Body Modifications
    Last Post: 06-05-2013, 05:58 AM
  2. Instrument Cluster
    By Iceman6669 in forum General Grand Prix Discussion
    Last Post: 12-31-2012, 05:54 PM
  3. Instrument Cluster Help
    By millerlite64 in forum Audio, Security & Visual Electronics
    Last Post: 09-25-2012, 02:25 PM
  4. 88 instrument cluster
    By jjhudecek in forum Audio, Security & Visual Electronics
    Last Post: 04-13-2011, 03:09 PM
  5. instrument cluster
    By 97detgp in forum General Tech Discussion
    Last Post: 06-01-2009, 09:57 AM
