Thread: boost gauge install questions!
Results 1 to 16 of 16
  1. #1 boost gauge install questions!
    GT Level Member des19's Avatar
    May 2011
    Ontario
    Hey guys just making sure I know everything before getting into this install next week. (mechanical boost gauge)
    Couple easy questions:
    1) what do people usually do for the dimmer and ground wiring for the gauge? I would like the backlighting to come on with the headlights at night. It has red led backlights so it will look pretty good with the red setup I have goin on.
    2) If your answer to question 1 is just wire it to the dimmer in the radio.... Can I still do this if my dimmer wire is not connected to anuthing behind the dash? I have a aftermarket pioneer unit with dvd and am not sure if I even have the dimmer wire wired to anything at all. IIRC there was one regular orange wire which i think is hooked up (using gmos-04 harness) and one orange/white wire coming from the head unit which IIRC I left un used.
    Can I wire it to the orange/white wire will that work?
    Additional info: Played around with the headlights to see if the head unit dims. I turned on my headlights and it seems the radio is always lit (not 100% sure).
    So anything easier than using the dimmer on the head unit??!
    04 gtp.
    thanks
  2. #2 Re: boost gauge install questions!
    GTP Level Member winterstorm's Avatar
    Jun 2012
    Connecticut
    im not sure on anything but i can tell you that your radio is always lit. i also have a poineer unit and it is definitely always lit.
    2005 Grand Prix GT
    Corsa Sport Catback, Thrasher Shift Kit, Custom Open Cone Intake, Spyder Chrome CCFL Halo Projector Headlights, CG LED Tail Lights, Pioneer DEH-33HD stereo unit, Alpine SPR-60C 2 way 6 1/2's, Kicker KS 6x9's
  3. #3 Re: boost gauge install questions!
    May 2011
    Ontario
    Quote Originally Posted by mwinters29 View Post
    yes that is what I thought. looks like it was always lit while turned on so I dont get the dimmer feature
    anyone?
  4. #4 Re: boost gauge install questions!
    May 2011
    Ontario
    bump need some info!
  5. #5 Re: boost gauge install questions!
    GTX Level Member blakgtp's Avatar
    Sep 2011
    Vancouver
    my radio dims when running or headlights are on. there should be an orange wire coming from the car if its not being used on the radio just use it for the gauges. if it is then splice into it
  6. #6 Re: boost gauge install questions!
    May 2011
    Ontario
    Quote Originally Posted by blakgtp View Post
    ok thanks i will give this a try. hopefully this way will work for me.
  7. #7 Re: boost gauge install questions!
    Oct 2011
    Southington, CT
    I just spliced into my fog light switch. Was not that hard.
  8. #8 Re: boost gauge install questions!
    May 2011
    Ontario
    How do u do that?
  9. #9 Re: boost gauge install questions!
    Oct 2011
    Southington, CT
    Quote Originally Posted by des19 View Post
    How do u do that?
    Pull the switch out and find out which wire is the ground and which one is the power wire running to the lights and tap into those wires. Its about a 10min job and keeps you from needing to add an extra switch some whete
  10. #10 Re: boost gauge install questions!
    Quote Originally Posted by 19GTP98 View Post
    Uhhh guy.
    Mechanical boost gauge.
    Not the aisle 4 autozone ricer sunpro crap.
  11. #11 Re: boost gauge install questions!
    Sep 2011
    Vancouver
    he is just explaining how to wire for the backlight
  12. #12 Re: boost gauge install questions!
    Yup, I see that.
    Two boost gauge threads from the same guy lost me.
  13. #13 Re: boost gauge install questions!
    May 2011
    Ontario
    technically one is for wiring the other is for vac/boost
  14. #14 Re: boost gauge install questions!
    Sep 2011
    Vancouver
    des19, i'm assuming you have a gauge pod, what "filler" gauges are you getting? are any of them somewhat useful? lol
  15. #15 Re: boost gauge install questions!
    Oct 2011
    Southington, CT
    Quote Originally Posted by blueguy91 View Post
    Uhhh guy.
    Yeah I know that. It was for the light.
  16. #16 Re: boost gauge install questions!
    May 2011
    Ontario
    I did the vent ball mod since i have an 04... if i went 3 pillar route i would have done boost, aeroforce, and somthing else...but i use torque so stuck with just a mech boost gauge.
  1. Why is my boost gauge only reading vacuum and no boost?
    By gtp02 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-21-2010, 02:26 PM
  2. dic boost gauge only shows half boost
    By SilvaMan61 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-10-2010, 07:40 PM
  3. boost gauge install
    By a98gtp4u in forum General Tech Discussion
    Last Post: 10-21-2009, 03:11 PM
