Thread: Having some troubles with my HID conversion kit...
Results 1 to 5 of 5
  1. #1 Having some troubles with my HID conversion kit...
    May 2012
    Tracy, California
    I bought an HID conversion kit off of ebay called Genssi for my 1997 Pontiac Grand Prix GTP and I got it for the 9007 bulbs and the 6000k bulb color. However, when I installed everything exactly as I was instructed to in the provided manual and started up the car, nothing happened. There was no light at all from either bulb, the only things that actually happened were the bulbs got kind of hot and the bulbs were sucked into the bulb holder through some kind of vacuum. I've tried everything from switching the pugs going into the ballasts to changing the fuse on the wire going to the positive battery terminal. Can someone please help, this went from an easy 45 minute install to 4 hours of debugging and testing theories!
  2. #2 Re: Having some troubles with my HID conversion kit...
    GTX Level Member SomeDudeAtHome's Avatar
    Buffalo, NY
    I'd say try a relay harness but it sounds like you've done that. Next best option is send them back if you still can and buy a set from somewhere more reputable. Hopefully you can send them back after having messed with them so much.
    Black 98 GT bought in summer of 2009 w/28K miles- GTX Rims, Retrofit headlights, tinted tails, 20% tint all around, KYB Excel-G's, WBS Lowering Springs, 33mm Dorman front sway bar, 22mm Addco rear sway bar, BMR trailing arms, BMR STBs front and rear, ZZP control arms, Poly motor mounts, ZZP CAI, Thrasher shift kit
  3. #3 Re: Having some troubles with my HID conversion kit...
    SE Level Member Jake U's Avatar
    Apr 2013
    Waukesha, WI
    If you are going to install HIDs then spend the money on them. Retro-Solutions Store I went with the digital brand 55w and they work perfectly. It came with the relay harness but I still sometimes have the issue of bulbs going out when I start my car. I think that is more of a battery problem since my interior lights also dim pretty hard when i start my car. But worth the money.
  4. #4 Re: Having some troubles with my HID conversion kit...
    GT Level Member WolvesSoulZ's Avatar
    Québec
    On the blue 3 pin socket, change them around till you find the right order, it's the most common thing with these ebay sets.
    2000 GT - L67 swapped SOLD | 2004 GT1 - Winter Beater - SOLD
    2004 GTP Comp-G - 3.3"/3.2", XP, #50 , 4" MAF, SD's, 180*, AL103's, HAI, Tuned, 06+ Dual pistons brakes, STB's, SSC's and FE3.
    2011 Audi A6 S-Line - Also Supercharged
  5. #5 Re: Having some troubles with my HID conversion kit...
    The Boss Iceman6669's Avatar
    Jun 2011
    Quote Originally Posted by WolvesSoulZ View Post
    That usually only effects the hi/low beam function on Bi-Xenons to my knowledge.
    2011 F-150 Yote powered
  1. lot of troubles
    By crazymind in forum General Tech Discussion
    Last Post: 09-05-2012, 08:18 PM
  2. HVAC troubles
    By ajramos26 in forum General Tech Discussion
    Last Post: 04-19-2011, 08:56 PM
  3. A/C Troubles, I'm all searched out.
    By JESSEGOTTA GP GT in forum General Tech Discussion
    Last Post: 04-17-2010, 04:58 PM
  4. Electrical Troubles
    By Orozco in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-17-2009, 12:00 AM
  5. Need some help with amp and sub troubles
    By Thunderturd in forum Audio, Security & Visual Electronics
    Last Post: 08-20-2009, 02:51 AM
