Quote Originally Posted by 2dee11 View Post
So I will lose my auto headlights?
Yes, if you wire the resistor you are disabling the auto on headlamps. When you turn the ign on they turn on. When cranking you are forcing low voltage upon the hid kit. The resistor tricks the bcm into thinking its daylight so they don't turn on with ign before cranking engine over. They also sell a time delay relay that won't turn them on for 15 sec after key is turned on.
I forgot the drl was in the park light on the new body, so the resistor trick will make drl function at night also.
Sent from my SCH-I535 using Tapatalk 4 Beta
