Thread: Huge gap between the grille and headlights
Results 1 to 15 of 15
  1. #1 Huge gap between the grille and headlights
    Dec 2012
    Hawai'i
    There's like a 2" gap between the headlights and center side of the bumper on my 01 gtp. Headlights are stock. How do I fix this? Is there a way to adjust the lights inward? Do you think there are bent bracets? I suspect the car has been in some sort of front end accident because the door slightly rubs the fender when I open it. How do I fix this also?
    Thanks!
    2002 Impala- SSC, AGX, 18" charger R/t rims w/8mm spacers, Magnaflow cat, U-bend delete, flowmaster 80 series crossflow, z28 tips, HAI, debadged, 35% tint, smoked headlights, full sound system
  2. #2 Re: Huge gap between the grille and headlights
    Pictures?
    And the door on fender problem is normal, the hinge sags over time and starts to clip the fender. Just take a pry bar with a rag over the end and with the door slightly open push the fender out a little.
  3. #3 Re: Huge gap between the grille and headlights
    GTX Level Member mofford12's Avatar
    Nov 2012
    Cincinnati
    you might have an aftermaket set of headlights im guessing.. i have the same gap it bothers me too
  4. #4 Re: Huge gap between the grille and headlights
    GTP Level Member mrlogic1234's Avatar
    Jul 2010
    Detroit
    I had aftermarket headlights and they didn't fit properly. Huge gap like you described. It's like they were an inch to small.
    Ryan
    2000 GTP Coupe Green/Grey - SOLD!
    2008 GXP Black/Ebony
  5. #5 Re: Huge gap between the grille and headlights
    Jul 2010
    Detroit
    It's adjustment screws on the headlight that can control how far out it sits from the grill somewhat.
    Ryan
  6. #6 Re: Huge gap between the grille and headlights
    Dec 2012
    Hawai'i
    Here's pictures and part numbers. Pretty sure they're stock.
    Ee-gm140l
    Ee-gml139
  7. #7 Re: Huge gap between the grille and headlights
    Dec 2008
    Lawndale, CA
    Try the adjustment screws to move the headlight from side to side.
  8. #8 Re: Huge gap between the grille and headlights
    GTP Level Member
    springfield IL
    Wow those lights have to be aimed sooooo bad.... Lol. You even see the road??
  9. #9 Re: Huge gap between the grille and headlights
    Dec 2012
    Hawai'i
    Honestly the car just sits at my parents house so I'm not even sure how the lights perform. I just bought it to make some money on but I've been busy and I cant figure out how to align the damn window regulator
  10. #10 Re: Huge gap between the grille and headlights
    GT Level Member sugaryuk's Avatar
    vancouver,bc
    I'd check and see if the brackets are seated correctly-- there are tabs on the back of the bracket that have to slide into place.
    02 GT- L32/Gen V, 3.3 mps, zz 1.9's, N*, slp front to back, OverKilled, 180 tstat, 104's, K&N cai, lowered with GMMP susp, 12" PBR brakes
    75 Pro-Street Vega-- Blown 383 stroker with Nos fogger system
  11. #11 Re: Huge gap between the grille and headlights
    Moderator DanPrixGTP's Avatar
    Jun 2011
    Grand Rapids, Michigan
    There are two adjustment screws on the headlights. One of the moves it up and down while the other does side to side.
    Forgot which screw does what, but all you need to do is screw the correct one and the headlight will move closer to grill.
    Also known as.... Aiming your headlights. You might want to give that a try.
  12. #12 Re: Huge gap between the grille and headlights
    Banned
    Sioux Falls, SD
    Car ever been in a wreck?
  13. #13 Re: Huge gap between the grille and headlights
    Dec 2012
    Hawai'i
    I have no clue if it's been in a wreck or not. I just bought it a few months ago. Clear title and I bought it from the second owner and he didn't know of any so I'd assume not.
    I'll look at the bracket and give the adjustment screws a try when I get up there to it again
  14. #14 Re: Huge gap between the grille and headlights
    Banned
    Sioux Falls, SD
    Whats the vin? I can pull a free carfax on it
  15. #15 Re: Huge gap between the grille and headlights
    Dec 2012
    Hawai'i
    Quote Originally Posted by MidnightBlue View Post
    No way! Sweet that would be awesome. I'll send you a pm when I go look at it
  1. HUGE bog off the line
    By gmachine in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-20-2011, 10:44 PM
  2. Huge sticky!!
    By blueguy in forum General Tech Discussion
    Last Post: 07-04-2009, 08:38 AM
  3. I Had A Huge Scare!
    By GTPJOE90 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-05-2008, 05:36 PM
